[postgis-users] ST_Transform Z heights between ODN and WSG
Paul Ramsey pramsey at cleverelephant.ca
Wed Feb 1 08:51:13 PST 2023
Before then, if there's a proj wizard around, a command-line call that
replicates the desired transform would be nice, to take proj out of
the equation as a source of the problem.
On Wed, Feb 1, 2023 at 8:48 AM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I'm seeing something similar in my environment, even going between two
> systems with explicit vertical datums.
> pramsey=# SELECT ST_AsTexT(ST_Transform('SRID=7405;POINT(545068 258591
> 8.51)'::geometry, 3901));
>                       st_astext
>  POINT Z (1681647.7511311213 6134585.208145529 8.51)
> Time to put it in the debugger.
> On Wed, Feb 1, 2023 at 4:13 AM James Howe <jmh205 at cam.ac.uk> wrote:
> > I can confirm it works in PostGIS 2.5, but not PostGIS 3.0+.
> > I've been using the official Docker images to test.
> > Time to file a bug then?
> > James
> > > I had postgresql10-postgis2.5 running.
> > > It didn't have 4979, so I inserted it.
> > > -- ERROR: GetProj4StringSPI: Cannot find SRID (4979) in spatial_ref_sys
> > > -- https://epsg.io/4979
> > > INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text, srtext) values ( 4979, 'EPSG', > 4979, '+proj=longlat +datum=WGS84 +no_defs +type=crs', 'None');
> > > SELECT ST_Transform('SRID=7405;POINT(545068 258591 8.51)'::geometry, 4979);
> > > That rendered me:
> > > st_transform                                                   |
> > > POINT Z(0.1215563454880247 52.20645574758174 55.02789907436818)|
> > > Met vriendelijke groet,
> > > Wouter Scherphof
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
