[postgis-users] Repeat operations on 50 tables of the same schema?
Hugues François hugues.francois at inrae.fr
Mon Feb 27 03:19:00 PST 2023
Sounds more like a generic postgresql question and you should be able to find most of the answers by reading the documentation. However, here are some basic suggestions:
- Add a prefix to the name of the table: "IGN_bdTopo_"
- Add a suffix to the table name: "_V1"
=> For both I would create a PLPGSQL function in order to loop over the table (list can be retrieved from postgreSQL catalogs or information_schema and execute the required alter table / rename statements.
- create a new "date" column of date type. And populate this field with the value: 06/15/2021
- create a new "source" column of type varchar (length 50). And populate this field with the value: 'ign'.
=> These are usual operations: alter table + add column and then update. Read the manual for details
- move all the elements of these 50 tables (including all). from the "ign" schema to the "ign_v2" schema. Whether data, constraints, indexes.
=> same thing as above using alter schema / rename, no need to move anything
Regards,
Hug
De: "celati Laurent" <laurent.celati at gmail.com>
À: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Envoyé: Lundi 27 Février 2023 11:49:40
Objet: [postgis-users] Repeat operations on 50 tables of the same schema?
Good morning,
I am new to Postgresql. I have 50 tables into a "ign" schema (schema other than public).
I would like for each of these 50 tables:
If someone could help me? Thank you so much.
[Fichier texte:ATT00001]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230227/3b914344/attachment.htm>
