[postgis-users] Upgrade 12->13 stuck due to postgis / raster issue
Jim VanPeursem jvp at jvp.llc
Mon Jan 23 15:14:24 PST 2023
Greetings,
[originally posted on pgsql-admin, but referred here]
I recently took over the management of a postgresql + postgis db on aws
rds. Given the age of this project, the db itself is probably ~7-8 years
old. It is currently on v12.12 and I'm unable to upgrade it to 13+. The db
does use postgis, but as far as I can tell, no raster or topology or other
postgis-related fields/features.
When I try to upgrade on aws, I get the following error:
The instance could not be upgraded because there are one or more databases
with an older version of PostGIS extension or its dependent extensions
(address_standardizer, address_standardizer_data_us,
postgis_tiger_geocoder, postgis_topology, postgis_raster) installed.
Please upgrade all installations of PostGIS and drop its dependent
extensions and try again.
SELECT postgis_full_version(); gives the following (reformatted for
clarity):
    POSTGIS="3.1.7 aafe1ff" [EXTENSION]
    PGSQL="120"
    GEOS="3.8.2-CAPI-1.13.4"
    PROJ="Rel. 5.2.0, September 15th, 2018"
    GDAL="GDAL 2.4.4, released 2020/01/08"
    LIBXML="2.9.1"
    LIBJSON="0.13.1"
    LIBPROTOBUF="1.3.2"
    WAGYU="0.5.0 (Internal)"
    RASTER (raster lib from "2.5.5 r0" need upgrade) [UNPACKAGED!] (raster
procs from "2.5.2 r17328" need upgrade)
Note that it lists RASTER both as being unpackaged and needing an upgrade,
even though postgis_raster is apparently not installed. My thinking is that
somewhere along the way, postgis_raster and possibly topology were
installed and later uninstalled (perhaps after being unbundled?).
For more clues, I issued the following command. For clarity I replace the
account numbers with pseudo-usernames for clarity. Also note that schema_1
and schema_2 are two schemas that the project uses.
db=> select a.extname, a.extowner, a.extnamespace, a.extversion, b.nspname,
b.nspowner from pg_catalog.pg_extension a, pg_namespace b where a.extname
LIKE '%postgis%';
     extname |  extowner  | extnamespace | extversion |      nspname
| nspowner
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_toast
| <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_temp_1
 | <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_toast_temp_1
 | <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_catalog
| <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | information_schema
| <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | extensions
| <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | schema_1
| <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | my_new_topo
 | <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | tiger
 | <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | tiger_data
| <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | topology
| <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | schema_2
| <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | public
| <local_admin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_temp_4
 | <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_toast_temp_4
 | <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_temp_5
 | <rdsadmin>
     postgis | <rdsadmin> |        16404 | 3.1.7      | pg_toast_temp_5
 | <rdsadmin>
I'm not familiar enough with postgresql nor postgis to understand whether
the nspname entries for tiger, topology, etc. are expected, or offer clues
as to the problem that I am encountering.
Some things that I've tried:
db=> SELECT postgis_extensions_upgrade();
NOTICE:  Extension postgis_raster is not available or not packagable for
some reason
NOTICE:  Extension postgis_topology is not available or not packagable for
some reason
NOTICE:  Extension postgis_tiger_geocoder is not available or not
packagable for some reason
Upgrade completed, run SELECT postgis_full_version(); for details
Also:
db=> select * from pg_available_extensions where name like 'postgis%';
          name          | default_version | installed_version |
             comment
 postgis                | 3.1.7           | 3.1.7             | PostGIS
geometry and geography spatial types and functions
 postgis_tiger_geocoder | 3.1.7           |                   | PostGIS
tiger geocoder and reverse geocoder
 postgis_topology       | 3.1.7           |                   | PostGIS
topology spatial types and functions
 postgis_raster         | 3.1.7           |                   | PostGIS
raster types and functions
(4 rows)
And:
db=> \dx
                                      List of installed extensions
     Name      | Version |   Schema   |
Description
 fuzzystrmatch | 1.1     | extensions | determine similarities and distance
between strings
 plpgsql       | 1.0     | pg_catalog | PL/pgSQL procedural language
 postgis       | 3.1.7   | extensions | PostGIS geometry, geography, and
raster spatial types and functions
 sslinfo       | 1.2     | public     | information about SSL certificates
(4 rows)
And:
db=> CREATE EXTENSION postgis_raster;
ERROR:  PostGIS Raster is already installed in schema 'extensions'
CONTEXT:  PL/pgSQL function inline_code_block line 10 at RAISE
And:
db=> DROP EXTENSION postgis_raster;
ERROR:  extension "postgis_raster" does not exist
I also did a snapshot backup and restored to a new instance on aws, and
this resulted in exactly the same problem on the new instance.
Erik Weinhold from the pgsql-admin mailing list helpfully pointed out the
following:
> Could be that someone "uninstalled" them by deleting from pg_extension.
> Deleting from pg_extension reproduces the error:
>         test=# create extension postgis_raster;
>         CREATE EXTENSION
>         test=# delete from pg_extension where extname = 'postgis_raster';
>         DELETE 1
>         test=# drop extension postgis_raster;
>         ERROR:  PostGIS Raster is already installed in schema 'public'
> That last error message does not come from checking pg_extension but rather
> postgis_raster itself[2].
> I tried  DROP SCHEMA extensions CASCADE  at this point to get rid of the
> remaining objects but that fails:
>         test=# drop schema extensions cascade;
>         ERROR:  cache lookup failed for extension 27232
Is there a way to either restore or remove the unbundled / partial raster
support so that it can be upgraded? Does anyone have other suggestions on
what I could try? I'd like to get to postgresql v13+ with only postgis (no
raster, topology, etc.) installed without losing any data along the
journey. Is my only recourse to do a full data backup to sql followed by
creating a new instance and restoring data?
Thanks,
->jvp
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230123/23d62673/attachment.htm>
