[postgis-users] ST_SummaryStats
Simon SPDBA Greener simon at spdba.com.au
Sun Jul 2 16:26:17 PDT 2023
Following the documentation I have crafted some GDAL to load, and SQL to
query, some rasters.
I note that :
1. If, when loading using GDAL, I don't tile the rasters I get a table
with a single row (toddriver_2019_2p5m)
2. If, when loading using GDAL, I specify a tile size (eg -t 256*256) I
get a table with multiple rows (toddriver_2019_3p0m)
Now if I execute ST_SummaryStats against 1 I get a single row which
looks correct.:
WITH data AS (
   SELECT '1' as band,
          'SRID=4283;POLYGON ((133.84747311077376 -23.74668364533433,
133.84747311077376 -23.7409001580403, 133.85607301067603
-23.7409001580403, 133.85607301067603 -23.746683645334333,
133.84747311077376 -23.74668364533433))'::geometry as geom
SELECT (stats).sum   as sum,
        (stats).mean  as mean,
        (stats).stddev as stddev,
        (stats).min   as min,
        (stats).max   as max,
        (stats).count as count
    FROM (SELECT
ST_SummaryStats(ST_Clip(ST_Band(raster,d.band),geom,true)) As stats
            FROM gis.toddriver_2019_2p5m
                 INNER JOIN data as d
                 ON ST_Intersects(d.geom,ST_Band(raster,d.band))
         ) As foo;
If I execute the above against 2) I get multiple summary statistics
rows, one for each of the tiles in the table.
To return the summary stats for 2 across all rows I did the following:
WITH data AS (
   SELECT '1' as band,
SELECT sum((stats).sum)   as sum,
        avg((stats).mean)  as mean,
        sqrt(sum((stats).stddev*(stats).stddev)/min(groups)) as stddev,
        min((stats).min)   as min,
        max((stats).max)   as max,
        sum((stats).count) as count
   FROM (SELECT row_number() over () as groups,
           FROM gis.toddriver_2019_3p0m as t
        ) As f;
I have tested this SQL against tiled and untiled versions of the same raster and the result looks correct.
Even so, I could like confirmed that this approach is correct for tiled rasters?
regards
Simon
Simon Greener
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
(m) +61 418 396 391
(w)www.spdba.com.au
(m)simon at spdba.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230703/1a109607/attachment.htm>
