[postgis-users] New PostGis Docker Images: Upgraded PostGIS to Versions 3.3.4 and 3.4.0beta2
Imre Samu pella.samu at gmail.com
Sat Jul 29 14:07:23 PDT 2023
Hello PostGIS users,
The PostGIS Docker project on GitHub (
https://github.com/postgis/docker-postgis)
has recently been updated with two new PostGIS versions for both Debian and
Alpine:
- PostGIS 3.3.4
- PostGIS 3.4.0beta2 ( (available as an alpine test image )
We now have the following test images available:
- postgis/postgis:14-master
- postgis/postgis:15-master
- postgis/postgis:16beta2-master
- postgis/postgis:15-3.4.0beta2-alpine
- postgis/postgis:16beta2-3.4.0beta2-alpine
- postgis/postgis:16beta2-3.3
- postgis/postgis:16beta2-3.3-alpine
Here is an example of the "postgis/postgis:16beta2-master" version
specifications:
-  PostgreSQL 16beta2 (Debian 16~beta2-1.pgdg110+1) on x86_64-pc-linux-gnu,
compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
-  POSTGIS="3.4.0dev 3.4.0beta2-1-g6c7661430" [EXTENSION] PGSQL="160"
GEOS="3.13.0dev-CAPI-1.18.0" SFCGAL="SFCGAL 1.5.0, CGAL 5.6.1, BOOST
1.74.0" PROJ="9.3.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" GDAL="GDAL
3.8.0dev-d5ae41aed1, released 2023/07/29" LIBXML="2.9.10" LIBJSON="0.15"
LIBPROTOBUF="1.3.3" WAGYU="0.5.0
For more information, please visit::
-  https://github.com/postgis/docker-postgis
Best regards,
   The PostGIS Docker Team.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230729/8f2de3c3/attachment.htm>
