[postgis-users] need help
Bekir Niyaz bagafoot at hotmail.com
Fri Mar 17 00:10:49 PDT 2023
Hello all,
I move db servers to newer servers but I misinstalled the new version of postgis, former posgis version was 3.0.0 but in new servers I realize I installed 3.3.2, therefore I get some errors  deprecated func like
ERROR,0A000,"A stored procedure tried to use deprecated C function 'pgis_geometry_union_finalfn'","Library function 'pgis_geometry_union_finalfn' was deprecated in PostGIS 3.3.2","Consider running: SELECT postgis_extensions_upgrade()"
Now what do you recommend me to do, should I remove postgis33_12-3.3.2-1.rhel8.x86_64 package and install postgis30_12.x86_64
or just run "SELECT postgis_extensions_upgrade()" and find alternate function to deprecated ones?
This is the prod server.
best regards.
thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230317/a49209c3/attachment.htm>
