[postgis-users] ERROR: transform: Point outside of projection domain (2050)
pham lan phamlankt at gmail.com
Mon Mar 27 13:58:42 PDT 2023
Sorry, my bad. I just realized that the information about the postgis
version I gave you was wrong. So the original one is 2.5 and the backup one
is 3.0. Can it be that the st_transform function caused the problem in this
case for different postgis functions?
So the output of select postgis_full_version() are following:
#This is the output from the original database
geodm=#  SELECT postgis_full_version();
 POSTGIS="2.5.5" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3"
SFCGAL="1.3.1" PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3,
released 2021/04/27" LIBXML="2.9.1" LIBJSON="0.11" LIBPROT
OBUF="1.0.2" (core procs from "2.5.2 r17328" need upgrade) TOPOLOGY
(topology procs from "2.5.2 r17328" need upgrade) RASTER (raster procs from
"2.5.2 r17328" need upgrade) (sfcgal procs from "2
#This is output of the target database:
geodm=# select postgis_full_version();
 POSTGIS="3.0.7 r487b488" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3"
SFCGAL="1.4.1" PROJ="8.2.1" GDAL="GDAL 3.2.3, released 2021/04/27"
LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
(core procs from "2.5.2 r17328" need upgrade) TOPOLOGY (topology procs from
"2.5.2 r17328" need upgrade) RASTER (raster lib from "2.5.5 r0" need
upgrade) (raster procs from "2.5.2 r17328" need u
pgrade) (sfcgal procs from "2.5.2 r17328" need upgrade)
On Mon, Mar 27, 2023 at 10:41 PM pham lan <phamlankt at gmail.com> wrote:
> you are right, if i dropped the aforementioned index, analyze works
> without  issue. As long as I tried to create the index again, it does not
> let me creating the index but throw the same error.
> But I wonder why it is working in the original database. What happened
> during the backup/restore that changed this?
> Btw, I see some small difference in the output of the original database.
> May be it sounds something to you?
> (1 row)
> On Mon, Mar 27, 2023 at 10:21 PM Regina Obe <lr at pcorp.us> wrote:
>> Could be your ST_Transform index triggering the issue and you have at
>> least one geometry out of bounds in there.
>> I’d try dropping your geobordervtc_geom_25832_idx  and then rerunning
>> analyze on the table.
>> If that does fix it then try to gigure out which geometry is at fault.
>> The 25632 is only good for utm zone 32N
>> https://epsg.io/25832
>> So I suspect you have a geometry way off from there causing the issue.
>> Or it could be missing grid datum shift files at fault too.
>> You can update your grid files by running at your command line:
>> projsync --all
>> As detailed here - https://proj.org/apps/projsync.html#index-0
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>> Behalf Of pham lan
>> Sent: Monday, March 27, 2023 4:02 PM
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>> Subject: Re: [postgis-users] ERROR: transform: Point outside of
>> Hi Regina,
>> Here are more information:
>> PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3, released 2021/04/27"
>> TOPOLOGY RASTER
>> (1 row)
>> On Mon, Mar 27, 2023 at 9:43 PM Regina Obe <lr at pcorp.us> wrote:
>> What’s the structure of the table in question?
>> \d+ name_of_table
>> Should give needed details.
>> Also output of
>> Behalf Of pham lan
>> Sent: Monday, March 27, 2023 3:27 PM
>> Subject: [postgis-users] ERROR: transform: Point outside of projection
>> domain (2050)
>> Hi everyone,
>> I need your help to figure this out. I have a DB in postgresql 10  with
>> postgis 2.5. I know postgresql 10 is not supported anymore and we have plan
>> to upgrade it soon but it is a different story.
>> The thing is, I want to make a copy of this DB, so I tried a
>> pg_basebackup to another postgres10+postgis 2.5 VM. After that, a vacuum
>> went well but the analyzer throws an error on 1 specific table:
>> i tried also pg_dump/pg_restore but get the same error. Does anyone know
>> what is the problem?
>> Thanks for your help!
>> Regards,
>> Lan
>> postgis-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230327/04c873ed/attachment.htm>
