[postgis-users] Failing ST_Transform with Ross Ice Shelf polygon
Paul Ramsey pramsey at cleverelephant.ca
Mon Nov 6 14:58:26 PST 2023
No, it’s more likely a problem with whatever you’re using to visualize the data. Proj doesn’t look at the structure of the data (line, poly) it just transforms everything, point by point. So your process (A to B to A) should really just be a null-trip. You can dump the points and see where it is not. The only thing I can think is that because the polygon includes a “cut line” down 180, if there’s even a little roundoff/drift from the proj process you might get points on the “wrong side” of that line, which your visualization then freaks out about.
P
> On Nov 6, 2023, at 2:07 PM, Marco Boeringa via postgis-users <postgis-users at lists.osgeo.org> wrote:
> Hi,
> I am seeing an issue with the following statement. It produces a globe spanning geometry in WGS 1984, instead of restricting it to the "right" Ross Ice Shelf polygon of OpenStreetMap. The data is a simplified version of the original OSM polygon, and the statement just for demonstration of the issue.
> Is this a possible issue with PROJ?
> Marco
> My configuration:
> Postgres version: 16.0 (Ubuntu 16.0-1.pgdg22.04+1)
> PostGIS version: POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="160" GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org <https://cdn.proj.org/> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db" LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
> Statement:
> WITH test AS (
> SELECT ST_Transform(ST_GeomFromText('POLYGON ((158.10695526625003 -80.39379956062496, 158.17512071475002 -80.37682427587495, 158.24328616325002 -80.35984899112495, 158.31145161175002 -80.34287370637495, 158.38114047087504 -80.33008053499995, 158.45235274062503 -80.32146947699994, 158.52356501037508 -80.31285841899995, 158.59477728012507 -80.30424736099994, 158.64668881875008 -80.28920047874995, 158.67929962625004 -80.26771777224995, 158.73533820112505 -80.25396313437496, 158.81480454337503 -80.24793656512496, 158.89427088562508 -80.24190999587496, 158.97373722787506 -80.23588342662497, 159.0664054406251 -80.22689298056247, 159.17227552387507 -80.21493865768747, 159.27814560712508 -80.20298433481247, 159.38401569037507 -80.19103001193747, 159.48988577362508 -80.17907568906247, 159.59575585687506 -80.16712136618747, 159.70162594012507 -80.15516704331247, 159.80749602337505 -80.14321272043748, 159.89495512875004 -80.13499242174997, 159.96400325625007 -80.13050614724996, 160.03305138375003 -80.12601987274995, 160.10209951125006 -80.12153359824994, 160.15194238875006 -80.11240580224994, 160.18258001625009 -80.09863648474995, 160.2494988771251 -80.08649922724996, 160.35269897137508 -80.07599402974995, 160.45589906562506 -80.06548883224997, 160.55909915987505 -80.05498363474996, 160.66778246875003 -80.03301389699996, 160.78194899225002 -79.99957961899995, 160.88691594475003 -79.98360664799995, 160.98268332625005 -79.98509498399997, 161.06635873837507 -79.98074917974998, 161.13794218112508 -79.97056923524997, 161.2095256238751 -79.96038929074996, 161.2811090666251 -79.95020934624995, 161.3386892805001 -79.93186949899994, 161.38226626550005 -79.90536974899995, 161.36895010950005 -79.89113050349995, 161.29874081250009 -79.88915176249996, 161.2294900840001 -79.89815292674997, 161.1611979240001 -79.91813399624998, 161.0790307177501 -79.93269654799998, 160.9829884652501 -79.94184058199998, 160.88694621275008 -79.95098461599999, 160.79090396025006 -79.96012864999999, 160.69711466275004 -79.95201439012499, 160.60557832025006 -79.92664183637498, 160.51404197775003 -79.90126928262498, 160.42250563525005 -79.87589672887498, 160.32397287275003 -79.86928572599997, 160.21844369025004 -79.88143627399997, 160.12671936462505 -79.89576009099997, 160.04879989587505 -79.91225717699996, 159.97088042712505 -79.92875426299997, 159.89296095837506 -79.94525134899996, 159.79698695725006 -79.95105370199997, 159.68295842375005 -79.94616132199997, 159.60096327925007 -79.92598102024996, 159.5510015237501 -79.89051279674996, 159.5456762440001 -79.86159112974995, 159.58498744000008 -79.83921601924995, 159.56570810300008 -79.82741875199994, 159.4878382330001 -79.82619932799994, 159.4849615486251 -79.81977196124996, 159.5570780498751 -79.80813665174995, 159.62919455112507 -79.79650134224997, 159.70131105237505 -79.78486603274996, 159.78942538562504 -79.77628589187498, 159.89353755087504 -79.77076091962496, 159.99764971612504 -79.76523594737498, 160.10176188137504 -79.75971097512496, 160.20958961350004 -79.74337897574996, 160.32113291250005 -79.71623994924995, 160.42377911337505 -79.69583252812495, 160.51752821612504 -79.68215671237496, 160.61127731887504 -79.66848089662497, 160.70502642162504 -79.65480508087498, 160.76163881000005 -79.64177897949997, 160.78111448400008 -79.62940259249996, 160.7561719681251 -79.62668682324994, 160.6868112623751 -79.63363167174995, 160.6174505566251 -79.64057652024994, 160.5480898508751 -79.64752136874995, 160.4555878335001 -79.65213713408328, 160.3399445045001 -79.65442381624995, 160.2243011755001 -79.65671049841661, 160.10865784650008 -79.65899718058328, 159.9930145175001 -79.66128386274995, 159.8773711885001 -79.66357054491662, 159.7860553172501 -79.65012655324996, 159.7190669037501 -79.62095188774997, 159.6861636850001 -79.58635348324997, 159.6873456610001 -79.54633133974995, 159.7415938232501 -79.53055345299995, 159.84890817175008 -79.53901982299996, 159.92432354700009 -79.55131125199996, 159.9678399490001 -79.56742773999996, 160.0348297732501 -79.57464533149995, 160.12529301975005 -79.57296402649995, 160.20360580950003 -79.56498297387495, 160.26976814250006 -79.55070217362496, 160.33593047550008 -79.53642137337496, 160.4020928085001 -79.52214057312497, 160.4378806675001 -79.50494737499997, 160.4432940525001 -79.48484177899996, 160.50373768275009 -79.46667922499996, 160.61921155825004 -79.45045971299997, 160.71254318325003 -79.44680545524997, 160.78373255775006 -79.45571645174996, 160.85492193225008 -79.46462744824996, 160.9261113067501 -79.47353844474995, 160.9621336345001 -79.46512276549994, 160.9629889155001 -79.43938041049994, 160.93186964925007 -79.42657883199993, 160.86877583575006 -79.42671802999996, 160.80568202225004 -79.42685722799996, 160.74258820875002 -79.42699642599999, 160.68512696000002 -79.41466089224998, 160.63329827600003 -79.38985062674998, 160.63883924025004 -79.37111987524997, 160.70174985275003 -79.35846863774998, 160.71139884100003 -79.34439663774998, 160.66778620500006 -79.32890387524998, 160.58925664750006 -79.31738938899997, 160.47581016850006 -79.30985317899996, 160.43534490950006 -79.29159469149995, 160.46786087050006 -79.26261392649995, 160.45613722050007 -79.22754593724996, 160.40017395950008 -79.18639072374997, 160.41635551050007 -79.15575249274997, 160.5046818735001 -79.13563124424996, 160.59300823650005 -79.11550999574996, 160.68133459950008 -79.09538874724996, 160.71403051125006 -79.07391149924996, 160.69109597175006 -79.05107825174997, 160.71524657775007 -79.04183828537498, 160.78648232925008 -79.04619160012496, 160.8577180807501 -79.05054491487496, 160.9289538322501 -79.05489822962494, 161.0146113105001 -79.03686639549994, 161.1146905155001 -78.99644941249994, 161.2249184137501 -78.96895894399995, 161.3452950052501 -78.95439498999997, 161.4473448307501 -78.96966517674997, 161.53106789025006 -79.01476950424995, 161.61064437987505 -79.04128216474996, 161.68607429962503 -79.04920315824995, 161.76150421937507 -79.05712415174997, 161.83693413912505 -79.06504514524997, 161.91738713450007 -79.06679086924997, 162.0028632055001 -79.06236132374995, 162.0137484256251 -79.04678765449995, 161.9500427948751 -79.02006986149993, 161.88633716412508 -78.99335206849995, 161.82263153337507 -78.96663427549993, 161.75997537250007 -78.92005910799995, 161.69836868150006 -78.85362656599997, 161.62540644000006 -78.81381381949998, 161.54108864800008 -78.80062086849998, 161.50763083950008 -78.78132505849997, 161.52503301450005 -78.75592638949998, 161.50346919050006 -78.72891300824998, 161.4429393675001 -78.70028491474997, 161.3951926980001 -78.66032357449997, 161.3602291820001 -78.60902898749997, 161.38167753175009 -78.56783775724996, 161.45953774725007 -78.53674988374995, 161.53112514662507 -78.52551132237494, 161.59643972987504 -78.53412207312496, 161.66175431312507 -78.54273282387496, 161.72706889637504 -78.55134357462498, 161.75659776950005 -78.56758427649997, 161.75034093250002 -78.59145492949996, 161.77679604600002 -78.61926421349996, 161.83596311000002 -78.65101212849997, 161.89433739725004 -78.66836687699997, 161.95191890775007 -78.67132845899995, 162.01592663650007 -78.69422582749995, 162.08636058350004 -78.73705898249996, 162.16317482250003 -78.76831847049996, 162.24636935350003 -78.78800429149996, 162.32956388450003 -78.80769011249996, 162.41275841550004 -78.82737593349995, 162.49331636900004 -78.86604772024995, 162.57123774500005 -78.92370547274996, 162.65672471700006 -78.94666283049996, 162.74977728500008 -78.93491979349996, 162.81541134100007 -78.90873518049996, 162.85362688500004 -78.86810899149997, 162.91127380850003 -78.83703033724997, 162.98835211150003 -78.81549921774997, 163.03629790625004 -78.78803662699997, 163.05511119275005 -78.75464256499995, 163.11081229937506 -78.73838509099994, 163.20340122612507 -78.73926420499996, 163.29599015287508 -78.74014331899994, 163.3885790796251 -78.74102243299996, 163.44621650300007 -78.75036797574995, 163.46890242300003 -78.76817994724996, 163.50187047750003 -78.76355604399997, 163.54512066650008 -78.73649626599997, 163.6130038492501 -78.72319890899998, 163.7055200257501 -78.72366397299997, 163.7980362022501 -78.72412903699997, 163.8905523787501 -78.72459410099997, 163.96768674875008 -78.71205030999997, 164.02943931225005 -78.68649766399997, 164.11202162575003 -78.66835928874997, 164.21543368925003 -78.65763518424995, 164.28900767425003 -78.63422274849995, 164.33274358075002 -78.59812198149996, 164.4052575199167 -78.58087453983329, 164.50654949175004 -78.58248042349996, 164.60784146358338 -78.58408630716661, 164.70913343541673 -78.5856921908333, 164.81042540725008 -78.58729807449996, 164.91171737908343 -78.58890395816663, 165.01457607075008 -78.59282916824995, 165.11900148225004 -78.59907370474994, 165.20461771412502 -78.60089876237494, 165.27142476637502 -78.59830434112494, 165.33823181862502 -78.59570991987495, 165.40503887087502 -78.59311549862495, 165.44899547225003 -78.58331045499996, 165.47010162275006 -78.56629478899997, 165.53894226362507 -78.55683255349997, 165.65551739487506 -78.55492374849997, 165.77209252612505 -78.55301494349997, 165.88866765737504 -78.55110613849997, 165.98493900462503 -78.55651717837497, 166.06090656787504 -78.56924806312497, 166.13687413112504 -78.58197894787497, 166.21284169437504 -78.59470983262497, 166.29928663550004 -78.62220448474997, 166.39620895450003 -78.66446290424997, 166.48492493775 -78.68917066174997, 166.56543458525005 -78.69632775724996, 166.64594423275003 -78.70348485274995, 166.72645388025006 -78.71064194824994, 166.80735485762506 -78.71311662262494, 166.88864716487507 -78.71090887587496, 166.96993947212508 -78.70870112912496, 167.0512317793751 -78.70649338237499, 167.1179030860001 -78.69956703849998, 167.1699533920001 -78.68792209749996, 167.1967115552501 -78.66411492149996, 167.19817757575004 -78.62814551049996, 167.15581470350003 -78.58414872149996, 167.06962293850006 -78.53212455449994, 166.98255364066674 -78.5057816844166, 166.89460681000008 -78.50512011124994, 166.8066599793334 -78.50445853808327, 166.71871314866678 -78.5037969649166, 166.6307663180001 -78.50313539174994, 166.54281948733345 -78.50247381858327, 166.4768345425001 -78.49713321424994, 166.43281148350005 -78.48711357874996, 166.36710549275003 -78.48047640924996, 166.27971657025003 -78.47722170574995, 166.19232764775003 -78.47396700224995, 166.10493872525004 -78.47071229874994, 166.02884533287505 -78.46408348887493, 165.96404747062502 -78.45408057262495, 165.89924960837504 -78.44407765637493, 165.834451746125 -78.43407474012494, 165.76199807350002 -78.41418396199994, 165.68188859050002 -78.38440532199995, 165.66547447025005 -78.35273438424996, 165.7127557127501 -78.31917114874996, 165.6851783232501 -78.28976908299995, 165.5827423017501 -78.26452818699997, 165.4803062802501 -78.23928729099995, 165.37787025875008 -78.21404639499997, 165.35697188387508 -78.19297398137496, 165.41761115562508 -78.17607005012496, 165.4782504273751 -78.15916611887496, 165.5388896991251 -78.14226218762497, 165.5783959190001 -78.11955709824997, 165.59676908700007 -78.09105085074998, 165.56787789975007 -78.06081787974998, 165.4917223572501 -78.02885818524996, 165.4282739680001 -78.02940537599996, 165.37753273200008 -78.06245945199997, 165.30281021975006 -78.09875342224997, 165.20410643125004 -78.13828728674996, 165.17924865825003 -78.16682716374996, 165.22823690075003 -78.18437305324997, 165.22211638575004 -78.20727793649998, 165.16088711325006 -78.23554181349998, 165.08097545012507 -78.25582952899998, 164.98238139637508 -78.26814108299996, 164.88378734262508 -78.28045263699997, 164.7851932888751 -78.29276419099995, 164.7301642955001 -78.30670321549995, 164.71870036250007 -78.32226971049995, 164.66670807600008 -78.32814186849996, 164.5741874360001 -78.32431968949996, 164.48014538075012 -78.31029846687497, 164.38458191025006 -78.28607820062496, 164.28901843975007 -78.26185793437497, 164.19345496925 -78.23763766812496, 164.09963054475003 -78.23364348549997, 164.00754516625005 -78.24987538649997, 163.90377408400008 -78.25861464149996, 163.7883172980001 -78.25986125049995, 163.73381836700008 -78.24746486649995, 163.74027729100004 -78.22142548949996, 163.79855844412504 -78.19992867462497, 163.908661826375 -78.18297442187497, 164.01876520862504 -78.16602016912498, 164.12886859087502 -78.14906591637498, 164.23753658300004 -78.12586403399997, 164.34476918500005 -78.09641452199996, 164.38140184575005 -78.06851701474996, 164.34743456525004 -78.04217151224996, 164.37710146850006 -78.02418483674997, 164.4704025555001 -78.01455698824996, 164.5672003245001 -78.01133479974996, 164.66749477550007 -78.01451827124995, 164.75709313087506 -78.00820863674996, 164.83599539062507 -77.99240589624996, 164.91489765037508 -77.97660315574997, 164.9937999101251 -77.96080041524998, 165.03349905750008 -77.93516501774998, 165.03399509250005 -77.89969696324998, 165.07622160537505 -77.87737086599998, 165.16017859612504 -77.86818672599998, 165.24413558687507 -77.85900258599997, 165.32809257762506 -77.84981844599997, 165.41740123500009 -77.83294002774997, 165.5120615590001 -77.80836733124997, 165.6051671987501 -77.79802393699997, 165.6967181542501 -77.80190984499997, 165.7985872565001 -77.81034664012498, 165.91077450550011 -77.82333432237496, 166.0229617545001 -77.83632200462498, 166.13514900350012 -77.84930968687496, 166.2473362525001 -77.86229736912497, 166.35952350150012 -77.87528505137496, 166.4717107505001 -77.88827273362497, 166.58389799950012 -77.90126041587496, 166.6830235402501 -77.90195807099997, 166.76908737275008 -77.89036569899997, 166.80131938025008 -77.87294347974998, 166.7797195627501 -77.84969141324999, 166.8061421240001 -77.81883243049998, 166.88058706400008 -77.78036653149996, 166.95071937637508 -77.75736252549996, 167.0165390611251 -77.74982041249996, 167.0823587458751 -77.74227829949996, 167.1481784306251 -77.73473618649996, 167.2147491463751 -77.71985812424995, 167.2820708931251 -77.69764411274997, 167.3493926398751 -77.67543010124996, 167.4167143866251 -77.65321608974998, 167.49995507300008 -77.63673143299997, 167.59911469900004 -77.62597613099996, 167.68210919562503 -77.62373630524996, 167.74893856287505 -77.63001195574995, 167.81576793012508 -77.63628760624997, 167.8825972973751 -77.64256325674995, 167.9735602822501 -77.64415858424996, 168.0886568847501 -77.64107358874998, 168.1669555152501 -77.64990278449997, 168.2084561737501 -77.67064617149995, 168.2632589635001 -77.68287922574994, 168.3313638845001 -77.68660194724994, 168.39946880550008 -77.69032466874994, 168.46757372650006 -77.69404739024993, 168.53551644125005 -77.68581831849994, 168.60329694975005 -77.66563745349995, 168.69329440775005 -77.65213770874996, 168.80550881525005 -77.64531908424996, 168.89229020625007 -77.63014215974997, 168.9536385807501 -77.60660693524997, 169.02727468850009 -77.58644446937498, 169.1131985295001 -77.56965476212497, 169.19912237050005 -77.55286505487499, 169.28504621150006 -77.53607534762497, 169.32565838125004 -77.51433502174997, 169.32095887975004 -77.48764407724995, 169.28746210075005 -77.46691314824994, 169.22516804425007 -77.45214223474994, 169.2278456310001 -77.43892854887494, 169.29549486100007 -77.42727209062494, 169.3631440910001 -77.41561563237494, 169.43079332100007 -77.40395917412494, 169.5159186615834 -77.39941024499994, 169.61852011275008 -77.40196884499994, 169.72112156391674 -77.40452744499996, 169.8237230150834 -77.40708604499994, 169.92632446625007 -77.40964464499996, 170.02892591741673 -77.41220324499996, 170.12161374937506 -77.40536509499996, 170.20438796212505 -77.38913019499996, 170.28716217487505 -77.37289529499996, 170.36993638762505 -77.35666039499996, 170.47017155993754 -77.34779317506246, 170.58786769181256 -77.34629363518746, 170.70556382368756 -77.34479409531247, 170.82325995556258 -77.34329455543747, 170.94095608743757 -77.34179501556247, 171.0586522193126 -77.34029547568747, 171.17634835118758 -77.33879593581247, 171.2940444830626 -77.33729639593747, 171.39853458666676 -77.33820595633331, 171.4898186620001 -77.34152461699998, 171.58110273733342 -77.34484327766666, 171.67238681266673 -77.3481619383333, 171.76367088800006 -77.35148059899998, 171.8549549633334 -77.35479925966665, 171.9492202390834 -77.35678465916665, 172.04646671525006 -77.35743679749999, 172.14371319141674 -77.35808893583331, 172.2409596675834 -77.35874107416666, 172.33820614375009 -77.35939321249998, 172.43545261991676 -77.36004535083332, 172.5454496746251 -77.36267042687498, 172.66819730787506 -77.36726844062497, 172.79094494112508 -77.37186645437498, 172.91369257437503 -77.37646446812496, 173.02633161950004 -77.38208902762497, 173.12886207650004 -77.38874013287497, 173.23139253350004 -77.39539123812497, 173.33392299050004 -77.40204234337497, 173.44475826625006 -77.40149268099997, 173.5638983607501 -77.39374225099995, 173.67833587000013 -77.39355209724994, 173.78807079400008 -77.40092221974996, 173.8978057180001 -77.40829234224995, 174.00754064200004 -77.41566246474997, 174.11010121700005 -77.41961123849997, 174.20548744300004 -77.42013866349997, 174.30087366900005 -77.42066608849997, 174.39625989500004 -77.42119351349997, 174.49164612100006 -77.42172093849997, 174.58703234700005 -77.42224836349997, 174.68241857300006 -77.42277578849998, 174.77780479900005 -77.42330321349998, 174.88051190912506 -77.42575075312497, 174.99053990337507 -77.43011840737496, 175.10056789762507 -77.43448606162495, 175.21059589187507 -77.43885371587494, 175.3095932930834 -77.44403284741661, 175.39756010125006 -77.45002345624994, 175.4855269094167 -77.45601406508328, 175.5734937175834 -77.4620046739166, 175.66146052575004 -77.46799528274994, 175.7494273339167 -77.47398589158327, 175.84828931825004 -77.48443315749994, 175.95804647875002 -77.49933708049994, 176.06780363925003 -77.51424100349993, 176.17756079975004 -77.52914492649995, 176.28731796025005 -77.54404884949994, 176.39707512075003 -77.55895277249995, 176.50683228125004 -77.57385669549994, 176.61658944175002 -77.58876061849995, 176.72634660225003 -77.60366454149994, 176.83610376275004 -77.61856846449996, 176.94586092325005 -77.63347238749995, 177.05561808375003 -77.64837631049996, 177.15377085137504 -77.65856466887496, 177.24031922612505 -77.66403746262495, 177.32686760087506 -77.66951025637496, 177.41341597562507 -77.67498305012495, 177.51765399529174 -77.67861204624995, 177.6395816598751 -77.68039724474997, 177.76150932445842 -77.68218244324996, 177.88343698904174 -77.68396764174997, 178.00536465362507 -77.68575284024996, 178.12729231820842 -77.68753803874998, 178.24921998279174 -77.68932323724997, 178.3711476473751 -77.69110843574998, 178.49307531195842 -77.69289363424997, 178.61500297654175 -77.69467883274999, 178.73693064112507 -77.69646403124997, 178.85885830570842 -77.69824922974999, 178.96518443625007 -77.69494979649998, 179.05590903275004 -77.68656573149998, 179.1574418728125 -77.68348385556249, 179.26978295643755 -77.68570416868748, 179.38212404006254 -77.68792448181249, 179.49446512368758 -77.69014479493748, 179.60680620731256 -77.69236510806249, 179.7191472909376 -77.69458542118748, 179.83148837456258 -77.69680573431249, 179.94382945818762 -77.69902604743748, 180.0000000000000 -77.7617893369537, 180.0000000000000 -77.8850956028611, 180.0000000000000 -78.00840186876852, 180.0000000000000 -78.1317081346759, 180.0000000000000 -78.25501440058332, 180.0000000000000 -78.37832066649072, 180.0000000000000 -78.50162693239814, 180.0000000000000 -78.62493319830554, 180.0000000000000 -78.74823946421296, 180.0000000000000 -78.87154573012035, 180.0000000000000 -78.99485199602776, 180.0000000000000 -79.11815826193516, 180.0000000000000 -79.24146452784258, 180.0000000000000 -79.36477079374998, 180.0000000000000 -79.4880770596574, 180.0000000000000 -79.61138332556479, 180.0000000000000 -79.7346895914722, 180.0000000000000 -79.8579958573796, 180.0000000000000 -79.98130212328702, 180.0000000000000 -80.10460838919442, 180.0000000000000 -80.22791465510184, 180.0000000000000 -80.35122092100923, 180.0000000000000 -80.47452718691665, 180.0000000000000 -80.59783345282405, 180.0000000000000 -80.72113971873146, 180.0000000000000 -80.84444598463887, 180.0000000000000 -80.96775225054628, 180.0000000000000 -81.09105851645367, 180.0000000000000 -81.21436478236109, 180.0000000000000 -81.33767104826849, 180.0000000000000 -81.4609773141759, 180.0000000000000 -81.58428358008331, 180.0000000000000 -81.70758984599073, 180.0000000000000 -81.83089611189811, 180.0000000000000 -81.95420237780553, 180.0000000000000 -82.07750864371293, 180.0000000000000 -82.20081490962035, 180.0000000000000 -82.32412117552775, 180.0000000000000 -82.44742744143517, 180.0000000000000 -82.57073370734255, 180.0000000000000 -82.69403997324997, 180.0000000000000 -82.81734623915737, 180.0000000000000 -82.94065250506479, 180.0000000000000 -83.06395877097219, 180.0000000000000 -83.18726503687961, 180.0000000000000 -83.310571302787, 180.0000000000000 -83.43387756869441, 180.0000000000000 -83.55718383460182, 180.0000000000000 -83.68049010050923, 180.0000000000000 -83.80379636641663, 180.0000000000000 -83.92710263232405, 180.0000000000000 -84.05040889823144, 180.0000000000000 -84.17371516413886, 180.0000000000000 -84.35867456299997, 179.89362549750007 -84.35147473099997, 179.82270916250008 -84.34667484299999, 179.75179282750003 -84.34187495499998, 179.69141243075003 -84.33149458449998, 179.64156797225004 -84.31553373149995, 179.65180495550004 -84.30316606824995, 179.72212338050002 -84.29439159474997, 179.720156249125 -84.28035743062497, 179.64590356137506 -84.26106357587497, 179.57165087362506 -84.24176972112497, 179.4973981858751 -84.22247586637496, 179.40362178433344 -84.20936191099996, 179.2903216690001 -84.20242785499997, 179.17702155366675 -84.19549379899996, 179.0637214383334 -84.18855974299998, 178.95042132300006 -84.18162568699998, 178.8371212076667 -84.17469163099999, 178.74470795925004 -84.17186321099999, 178.67318157775009 -84.17314042699996, 178.60165519625008 -84.17441764299997, 178.53012881475013 -84.17569485899995, 178.4822041262501 -84.16206253974995, 178.45788113075008 -84.13352068524996, 178.39514247700006 -84.12540255974997, 178.29398816500006 -84.13770816324998, 178.21794126225006 -84.13827766099998, 178.16700176875008 -84.12711105299995, 178.0861172812501 -84.11666547999994, 177.97528779975008 -84.10694094199994, 177.86445831825006 -84.09721640399994, 177.75362883675007 -84.08749186599994, 177.64279935525005 -84.07776732799994, 177.53196987375003 -84.06804278999994, 177.42556812625006 -84.06379834049994, 177.3235941127501 -84.06503397949996, 177.23412412662512 -84.05963764512497, 177.1571581678751 -84.04760933737496, 177.0801922091251 -84.03558102962496, 177.0032262503751 -84.02355272187496, 176.92025084641676 -84.0130429168333, 176.83126599725009 -84.00405161449996, 176.7422811480834 -83.99506031216663, 176.65329629891676 -83.98606900983327, 176.56431144975008 -83.97707770749994, 176.4753266005834 -83.9680864051666, 176.38828576712507 -83.96216064149993, 176.30318894937506 -83.95930041649996, 176.21809213162504 -83.95644019149995, 176.13299531387503 -83.95357996649997, 176.03985468962503 -83.95351788337497, 175.93867025887505 -83.95625394212497, 175.83748582812507 -83.95899000087498, 175.7363013973751 -83.96172605962498, 175.6378108940001 -83.96012536137498, 175.5420143180001 -83.95418790612497, 175.4462177420001 -83.94825045087497, 175.3504211660001 -83.94231299562496, 175.33080506450008 -83.93077218099995, 175.38736943750004 -83.91362800699994, 175.36947068608336 -83.89888992174994, 175.27710881025004 -83.88655792524995, 175.18474693441672 -83.87422592874995, 175.0923850585834 -83.86189393224996, 175.00002318275008 -83.84956193574996, 174.90766130691676 -83.83722993924997, 174.8249976042501 -83.83248416124997, 174.7520320747501 -83.83532460174996, 174.67906654525007 -83.83816504224995, 174.60610101575008 -83.84100548274995, 174.52185699300009 -83.84766574774994, 174.42633447700007 -83.85814583724996, 174.3308119610001 -83.86862592674996, 174.2352894450001 -83.87910601624998, 174.1349838682501 -83.88394855849997, 174.02989523075004 -83.88315355349995, 173.96868271450003 -83.87623362699995, 173.95134631950006 -83.86318877899996, 173.9066585228751 -83.86088580624997, 173.83461932462507 -83.86932470874996, 173.7625801263751 -83.87776361124997, 173.69054092812507 -83.88620251374996, 173.60600670625007 -83.88904002924997, 173.50897746075003 -83.88627615774996, 173.42281110150003 -83.87667722549996, 173.34750762850007 -83.86024323249997, 173.3583854848751 -83.84109184674998, 173.45544467062507 -83.81922306824995, 173.5525038563751 -83.79735428974996, 173.64956304212507 -83.77548551124994, 173.65130844675008 -83.76227186674996, 173.55774007025008 -83.75771335624995, 173.46417169375007 -83.75315484574998, 173.37060331725007 -83.74859633524997, 173.30476131350008 -83.74009976249998, 173.2666456825001 -83.72766512749998, 173.20407852741678 -83.71642626924996, 173.1170598482501 -83.70638318774996, 173.03004116908346 -83.69634010624995, 172.94302248991676 -83.68629702474996, 172.8560038107501 -83.67625394324995, 172.76898513158343 -83.66621086174995, 172.6770910885001 -83.66238447574995, 172.5803216815001 -83.66477478524996, 172.4892458045001 -83.67058132524997, 172.40386345750008 -83.67980409574997, 172.31848111050007 -83.68902686624998, 172.23309876350007 -83.69824963674998, 172.14771641650006 -83.70747240724998, 172.06233406950005 -83.71669517774998, 171.99178284250004 -83.71277775774998, 171.93606273550003 -83.69572014724996, 171.94373098600005 -83.68413754899996, 172.0147875940001 -83.67802996299997, 172.04350149025012 -83.66342016624998, 172.02987267475012 -83.64030815874997, 171.9886833261251 -83.62398867012497, 171.9199334443751 -83.61446170037497, 171.85118356262507 -83.60493473062498, 171.78243368087504 -83.59540776087498, 171.7052703039167 -83.58701632916664, 171.61969343175005 -83.57976043549998, 171.5341165595834 -83.57250454183331, 171.44853968741674 -83.56524864816664, 171.36296281525009 -83.55799275449998, 171.27738594308343 -83.55073686083331, 171.2908933082501 -83.54186240174997, 171.4034849107501 -83.53136937724994, 171.5193055805001 -83.51432447249994, 171.63835531750004 -83.49072768749994, 171.63948182475002 -83.47304319199995, 171.52268510225002 -83.46127098599996, 171.40588837975002 -83.44949877999997, 171.28909165725003 -83.43772657399998, 171.17810155475001 -83.43083134124998, 171.07291807225005 -83.42881308174998, 170.96773458975002 -83.42679482224997, 170.86255110725006 -83.42477656274997, 170.76381686337504 -83.42881983612497, 170.67153185812504 -83.43892464237496, 170.57924685287503 -83.44902944862497, 170.48696184762503 -83.45913425487495, 170.42682508350003 -83.47152826049997, 170.39883656050006 -83.48621146549998, 170.33441583850006 -83.49036087174997, 170.23356291750005 -83.48397647924995, 170.16407420100006 -83.46239784524994, 170.1259496890001 -83.42562496974995, 170.06522686425012 -83.40230281787495, 169.98190572675009 -83.39243138962496, 169.8985845892501 -83.38255996137497, 169.81526345175007 -83.37268853312497, 169.71210926375008 -83.36771334724997, 169.58912202525008 -83.36763440374997, 169.46739294400007 -83.36082529699998, 169.34692202000005 -83.34728602699998, 169.23053054262505 -83.34377859987498, 169.11821851187506 -83.35030301562497, 169.00590648112507 -83.35682743137497, 168.89359445037508 -83.36335184712496, 168.78958206075006 -83.37273717274996, 168.69386931225003 -83.38498340824998, 168.60533371425004 -83.38226648174998, 168.52397526675009 -83.36458639324997, 168.43639744562512 -83.35748206699995, 168.34260025087508 -83.36095350299996, 168.2488030561251 -83.36442493899995, 168.15500586137506 -83.36789637499996, 168.06967384075006 -83.36272709124995, 167.99280699425003 -83.34891708774995, 167.96061124350004 -83.33224051749995, 167.97308658850008 -83.31269738049996, 168.0166319555001 -83.30203132399996, 168.09124734450012 -83.30024234799995, 168.1658627335001 -83.29845337199995, 168.24047812250012 -83.29666439599995, 168.3085508495001 -83.28834530937496, 168.3700809145001 -83.27349611212495, 168.4316109795001 -83.25864691487496, 168.4931410445001 -83.24379771762494, 168.5045895665001 -83.23087386199995, 168.4659565455001 -83.21987534799996, 168.48562839725008 -83.21107484899997, 168.56360512175007 -83.20447236499996, 168.64158184625006 -83.19786988099997, 168.71955857075005 -83.19126739699996, 168.78196331625006 -83.18042206624997, 168.82879608275007 -83.16533388874998, 168.82748169575007 -83.14061167799998, 168.77802015525003 -83.10625543399998, 168.71712594625004 -83.08410825949997, 168.64479906875007 -83.07417015449997, 168.59021290425008 -83.05256526624997, 168.55336745275005 -83.01929359474998, 168.47940317750005 -82.99784448912499, 168.36832007850006 -82.98821794937498, 168.25723697950008 -82.97859140962498, 168.1461538805001 -82.96896486987498, 168.05209263887508 -82.97564350224998, 167.9750532546251 -82.99862730674998, 167.89801387037505 -83.02161111124998, 167.82097448612507 -83.04459491574998, 167.72854263050004 -83.05634429699998, 167.62071830350004 -83.05685925499998, 167.53911125875004 -83.03830321049998, 167.48372149625004 -83.00067616349997, 167.39821685625006 -82.97779442399997, 167.2825973387501 -82.96965799199995, 167.2582875627501 -82.95485886524995, 167.32528752825007 -82.93339704374995, 167.31251154275006 -82.91791967049996, 167.21995960625006 -82.90842674549997, 167.21024571925005 -82.89545226549997, 167.28336988175005 -82.87899623049996, 167.30668567625005 -82.85475061049996, 167.28019310275008 -82.82271540549996, 167.22391484137506 -82.80086214574996, 167.13785089212507 -82.78919083124995, 167.05178694287503 -82.77751951674995, 166.96572299362504 -82.76584820224994, 166.88115251075 -82.76134161012494, 166.79807549425 -82.76399974037496, 166.71499847775002 -82.76665787062497, 166.63192146125002 -82.76931600087498, 166.55137634925003 -82.76664521399998, 166.47336314175007 -82.75864550999997, 166.4536589205001 -82.74223616549996, 166.4922636855001 -82.71741718049996, 166.4741801026251 -82.69739860499996, 166.39940817187505 -82.68218043899998, 166.32463624112506 -82.66696227299997, 166.24986431037502 -82.65174410699998, 166.16550724450002 -82.64647654049998, 166.07156504350002 -82.65115957349997, 165.96989916725002 -82.64522425599996, 165.86050961575003 -82.62867058799996, 165.75404468625004 -82.61833704362496, 165.65050437875004 -82.61422362287496, 165.54696407125004 -82.61011020212496, 165.44342376375005 -82.60599678137496, 165.43586703325005 -82.57794272749996, 165.52429387975005 -82.52594804049997, 165.51711586700006 -82.49135180549997, 165.41433299500008 -82.47415402249997, 165.3416140842501 -82.45110244199996, 165.2989591347501 -82.42219706399995, 165.2385067421251 -82.40609574637494, 165.1602569063751 -82.40279848912493, 165.0820070706251 -82.39950123187495, 165.0037572348751 -82.39620397462494, 164.9258409885001 -82.38746251637494, 164.84825833150006 -82.37327685712495, 164.77067567450007 -82.35909119787493, 164.69309301750002 -82.34490553862494, 164.62553030200004 -82.34536834624994, 164.5679875280001 -82.36047962074996, 164.5053459738751 -82.37019427062496, 164.4376056396251 -82.37451229587496, 164.3698653053751 -82.37883032112497, 164.3021249711251 -82.38314834637497, 164.2161631342001 -82.38730103739996, 164.1119797946001 -82.39128839419998, 164.0077964550001 -82.39527575099997, 163.9036131154001 -82.39926310779998, 163.7994297758001 -82.40325046459998, 163.69524643620008 -82.40723782139997, 163.59106309660007 -82.41122517819997, 163.48687975700008 -82.41521253499998, 163.38269641740007 -82.41919989179998, 163.27851307780008 -82.42318724859999, 163.21880269200008 -82.43274652274998, 163.2035652600001 -82.44787771424997, 163.2452375505001 -82.46432445149996, 163.3438195635001 -82.48208673449996, 163.4181370185001 -82.50434023774996, 163.4681899155001 -82.53108496124996, 163.47287391950007 -82.54848576999996, 163.43218903050004 -82.55654266399995, 163.35986296537504 -82.56018020262495, 163.25589572412503 -82.55939838587496, 163.15192848287506 -82.55861656912496, 163.04796124162505 -82.55783475237497, 162.94845355125005 -82.54195242949997, 162.85340541175003 -82.51096960049996, 162.75323322025002 -82.49229792812496, 162.64793697675003 -82.48593741237495, 162.54264073325004 -82.47957689662495, 162.43734448975005 -82.47321638087494, 162.33664165700006 -82.47276479641661, 162.24053223500005 -82.47822214324995, 162.14442281300006 -82.48367949008329, 162.04831339100002 -82.48913683691663, 161.95220396900004 -82.49459418374997, 161.85609454700003 -82.5000515305833, 161.74698719875005 -82.50416691987498, 161.62488192425002 -82.50694035162498, 161.50277664975005 -82.50971378337498, 161.38067137525002 -82.51248721512498, 161.29702080975005 -82.52153236624997, 161.2518249532501 -82.53684923674996, 161.1669174087501 -82.54054296374996, 161.04229817625006 -82.53261354724997, 160.98032367500005 -82.52316872224996, 160.98099390500008 -82.51220848874995, 160.9439492393751 -82.50319279787495, 160.86918967812508 -82.49612164962495, 160.79443011687508 -82.48905050137496, 160.71967055562507 -82.48197935312497, 160.63514221837505 -82.47782909712498, 160.54084510512507 -82.47659973337497, 160.44654799187504 -82.47537036962498, 160.35225087862506 -82.47414100587497, 160.26410972900004 -82.46100492949998, 160.18212454300004 -82.43596214049998, 160.19845073125003 -82.42341525549998, 160.31308829375007 -82.42336427449999, 160.42772585625005 -82.42331329349997, 160.54236341875009 -82.42326231249999, 160.64136321991674 -82.41725989449998, 160.72472525975007 -82.40530603949998, 160.8080872995834 -82.39335218449997, 160.89144933941674 -82.38139832949997, 160.97481137925007 -82.36944447449997, 161.0581734190834 -82.35749061949997, 161.15020532390008 -82.34821343924997, 161.25090709370005 -82.34161293374996, 161.35160886350008 -82.33501242824997, 161.45231063330007 -82.32841192274996, 161.55301240310007 -82.32181141724996, 161.6537141729001 -82.31521091174997, 161.7544159427001 -82.30861040624997, 161.8551177125001 -82.30200990074997, 161.95581948230011 -82.29540939524998, 162.05652125210008 -82.28880888974996, 162.14715125650008 -82.27885464124996, 162.22770949550005 -82.26554664974996, 162.27722482450005 -82.24418038249996, 162.2956972435001 -82.21475583949996, 162.2711962977501 -82.19755877887496, 162.20372198725008 -82.19258920062495, 162.13624767675006 -82.18761962237497, 162.06877336625004 -82.18265004412496, 161.98227754075003 -82.17130364199997, 161.87676020025003 -82.15358041599998, 161.86594249475004 -82.13342041774999, 161.94982442425007 -82.11082364724999, 162.0414214387501 -82.10251460983332, 162.1407335382501 -82.10849330549998, 162.2400456377501 -82.11447200116663, 162.3393577372501 -82.1204506968333, 162.4386698367501 -82.12642939249996, 162.5379819362501 -82.13240808816661, 162.6317037570001 -82.14208723824996, 162.7198352990001 -82.15546684274997, 162.79465874287507 -82.17045564724998, 162.8561740886251 -82.18705365174998, 162.91768943437506 -82.20365165624997, 162.9792047801251 -82.22024966074997, 163.05441317087508 -82.23130546437497, 163.14331460662504 -82.23681906712497, 163.23221604237506 -82.24233266987497, 163.32111747812502 -82.24784627262497, 163.41418305500002 -82.24864885862496, 163.51141277300007 -82.24474042787497, 163.60864249100007 -82.24083199712496, 163.70587220900012 -82.23692356637497, 163.7837623442501 -82.22432540549997, 163.8423128967501 -82.20303751449998, 163.8402681078751 -82.18886248787499, 163.77762797762506 -82.18180032562498, 163.71498784737508 -82.17473816337497, 163.65234771712505 -82.16767600112496, 163.64491181750006 -82.15894304799995, 163.69268014850005 -82.14853930399995, 163.67326427850006 -82.13762378024995, 163.5866642075001 -82.12619647674995, 163.5418074115001 -82.11088878749996, 163.53869389050004 -82.09170071249997, 163.49130809250002 -82.08128864974998, 163.39965001750002 -82.07965259924998, 163.318865306625 -82.06666604137499, 163.24895395987505 -82.04232897612496, 163.17904261312503 -82.01799191087497, 163.10913126637507 -81.99365484562495, 163.03944112975006 -81.97376306987495, 162.96997220325005 -81.95831658362495, 162.90050327675004 -81.94287009737495, 162.83103435025004 -81.92742361112495, 162.75934683825005 -81.92293983774995, 162.6854407407501 -81.92941877724995, 162.6593746495001 -81.92112852949995, 162.6811485645001 -81.89806909449996, 162.75034599125007 -81.88857228774997, 162.86696692975005 -81.89263810924997, 162.95478032150004 -81.88814384574997, 163.01378616650004 -81.87508949724995, 163.00149860600004 -81.85271572149995, 162.91791764000004 -81.82102251849997, 162.83183997641672 -81.80907688149999, 162.74326561525004 -81.81687881049999, 162.6546912540834 -81.8246807395, 162.56611689291668 -81.83248266849998, 162.47754253175003 -81.84028459749999, 162.38896817058335 -81.84808652649998, 162.32392551000004 -81.84534641449999, 162.28241455000006 -81.83206426149998, 162.30200762187508 -81.81670935249997, 162.38270472562505 -81.79928168749998, 162.46340182937507 -81.78185402249997, 162.54409893312504 -81.76442635749999, 162.55350589175006 -81.74995671924998, 162.49162270525008 -81.73844510774998, 162.4297395187501 -81.72693349624998, 162.3678563322501 -81.71542188474999, 162.36705199125012 -81.70618723799998, 162.42732649575012 -81.69922955599998, 162.4204848282501 -81.68751347074998, 162.34652698875004 -81.67103898224998, 162.25689320675002 -81.65954302437498, 162.15158348225003 -81.65302559712498, 162.04627375775004 -81.64650816987498, 161.94096403325005 -81.63999074262497, 161.91351691025005 -81.63304521699997, 161.96393238875004 -81.62567159299998, 161.94177525775004 -81.62136547612498, 161.84704551725005 -81.62012686637497, 161.75231577675007 -81.61888825662497, 161.65758603625008 -81.61764964687497, 161.5647685755001 -81.61203959624996, 161.4738633945001 -81.60205810474994, 161.46195594750012 -81.59031059924995, 161.5290462345001 -81.57679707974997, 161.51161811575008 -81.56554116774997, 161.40967159125006 -81.55654286324996, 161.31122928075007 -81.55488372087495, 161.21629118425005 -81.56056374062496, 161.1213530877501 -81.56624376037496, 161.02641499125008 -81.57192378012496, 161.0160088020001 -81.56127598049996, 161.0901345200001 -81.53430036149994, 161.1751925255001 -81.51576431137494, 161.2711828185001 -81.50566783012496, 161.3671731115001 -81.49557134887496, 161.4631634045001 -81.48547486762499, 161.4998740265001 -81.46980334249999, 161.47730497750007 -81.44855677349999, 161.4168013350834 -81.43804599016666, 161.31836309925006 -81.43827099249998, 161.21992486341674 -81.43849599483332, 161.1214866275834 -81.43872099716663, 161.02304839175008 -81.43894599949996, 160.92461015591675 -81.43917100183329, 160.93265563100007 -81.42535654049996, 161.04718481700004 -81.39750261549997, 161.06669753762503 -81.38016968587498, 160.99119379287504 -81.37335775162497, 160.91569004812504 -81.36654581737496, 160.84018630337505 -81.35973388312495, 160.74138704275003 -81.36104634212495, 160.61929226625006 -81.37048319437494, 160.49719748975002 -81.37992004662496, 160.37510271325004 -81.38935689887495, 160.30674592775003 -81.38449406349996, 160.29212713325003 -81.36533154049995, 160.31343065425006 -81.34586608674995, 160.3706564907501 -81.32609770224995, 160.3444543550001 -81.31396563224996, 160.23482424700012 -81.30946987674994, 160.1251941390001 -81.30497412124996, 160.0155640310001 -81.30047836574994, 159.9322744640001 -81.28510098937494, 159.87532543800006 -81.25884199212496, 159.81837641200008 -81.23258299487495, 159.76142738600004 -81.20632399762496, 159.74218224275006 -81.18730439224996, 159.7606409822501 -81.17552417874995, 159.8296359737501 -81.16594589674996, 159.94916721725008 -81.15856954624998, 160.03395511525008 -81.16619368824998, 160.0839996677501 -81.18881832274995, 160.16334262600012 -81.20346199224994, 160.2719839900001 -81.21012469674994, 160.3806253540001 -81.21678740124995, 160.4892667180001 -81.22345010574995, 160.5788984350001 -81.23041670999996, 160.64952050500005 -81.23768721399995, 160.72014257500007 -81.24495771799997, 160.79076464500002 -81.25222822199996, 160.84525353975005 -81.24952276024996, 160.88360925925008 -81.23684133274995, 160.8638283180001 -81.22830589287494, 160.78591071600007 -81.22391644062495, 160.70799311400006 -81.21952698837495, 160.63007551200005 -81.21513753612496, 160.63308871000004 -81.20752747349997, 160.71703270800003 -81.19669680049998, 160.74838731750003 -81.18095661824998, 160.72715253850004 -81.16030692674997, 160.66842577975004 -81.14181122474996, 160.57220704125004 -81.12546951224995, 160.56050176000002 -81.11529863649994, 160.63330993600005 -81.11129859749997, 160.706118112 -81.10729855849996, 160.77892628800004 -81.10329851949999, 160.78331607725002 -81.09545360412498, 160.71928747975002 -81.08376381237498, 160.65525888225002 -81.07207402062498, 160.59123028475003 -81.06038422887498, 160.56991661675005 -81.04103668824997, 160.5913178782501 -81.01403139874996, 160.6326044912501 -80.99665266549997, 160.69377645575008 -80.98890048849998, 160.75588172575007 -80.96786187249998, 160.81892030125007 -80.93353681749997, 160.81532531450006 -80.91307438712496, 160.74509676550008 -80.90647458137497, 160.67486821650004 -80.89987477562497, 160.60463966750007 -80.89327496987497, 160.57364276750005 -80.88560407324997, 160.58187751650004 -80.87686208574996, 160.5325877466667 -80.86987638424996, 160.42577345800004 -80.86464696874997, 160.31895916933337 -80.85941755324997, 160.2121448806667 -80.85418813774997, 160.10533059200003 -80.84895872224998, 159.99851630333336 -80.84372930674998, 159.96053618375004 -80.83470559324998, 159.99139023325006 -80.82188758174998, 160.05630507187507 -80.81269234212498, 160.15528069962508 -80.80711987437498, 160.2542563273751 -80.80154740662498, 160.3532319551251 -80.79597493887498, 160.4604042472501 -80.79606023174998, 160.5757732037501 -80.80180328524997, 160.6687863140001 -80.80157726574997, 160.73944357800008 -80.79538217324996, 160.8101008420001 -80.78918708074995, 160.8807581060001 -80.78299198824995, 160.9627183882501 -80.78170475749995, 161.05598168875008 -80.78532538849997, 161.07532401650008 -80.77905814399998, 161.02074537150008 -80.76290302399997, 161.02739949500008 -80.74768757249997, 161.09528638700007 -80.73341178949998, 161.13239511575006 -80.70605953024999, 161.13872568125004 -80.66563079474999, 161.08070644050002 -80.63739291699999, 160.95833739350002 -80.62134589699998, 160.85885829325002 -80.61412250899998, 160.78226913975004 -80.61572275299999, 160.68900317300006 -80.62819347174998, 160.57906039300008 -80.65153466524997, 160.46831092850007 -80.66875836624996, 160.35675477950005 -80.67986457474996, 160.24108459962503 -80.68050268362495, 160.12130038887506 -80.67067269287497, 160.00151617812503 -80.66084270212497, 159.88173196737506 -80.65101271137499, 159.80903206525005 -80.63015580324998, 159.78341647175006 -80.59827197774996, 159.81770011750007 -80.57469832449995, 159.91188300250008 -80.55943484349994, 159.98307335525007 -80.55929281024994, 160.03127117575005 -80.57427222474995, 160.10360011925005 -80.57774867158328, 160.20006018575003 -80.56972215074995, 160.29652025225005 -80.56169562991661, 160.39298031875 -80.5536691090833, 160.48944038525002 -80.54564258824996, 160.58590045175 -80.53761606741664, 160.61032665800002 -80.51892817674997, 160.56271900400003 -80.48957891624997, 160.58370527475003 -80.47369389399996, 160.67328547025002 -80.47127310999996, 160.77042682400003 -80.48222142324995, 160.87512933600004 -80.50653883374996, 160.95134021400006 -80.51480957124996, 160.99905945800006 -80.50703363574995, 160.98769759162508 -80.48764746912494, 160.91725461487505 -80.45665107137495, 160.84681163812508 -80.42565467362493, 160.77636866137505 -80.39465827587495, 160.68926491612507 -80.38239025374995, 160.58550040237503 -80.38885060724994, 160.48173588862505 -80.39531096074995, 160.37797137487502 -80.40177131424994, 160.27617763875003 -80.40395818424994, 160.17635468025003 -80.40187157074996, 160.07653172175003 -80.39978495724995, 159.97670876325003 -80.39769834374997, 159.87588041025003 -80.39964860281246, 159.77404666275004 -80.40563573443745, 159.67221291525004 -80.41162286606246, 159.57037916775005 -80.41760999768745, 159.46854542025005 -80.42359712931245, 159.36671167275006 -80.42958426093745, 159.26487792525006 -80.43557139256245, 159.16304417775007 -80.44155852418744, 159.06697175425006 -80.44409592258327, 158.97666065475008 -80.44318358774994, 158.8863495552501 -80.44227125291661, 158.79603845575008 -80.44135891808327, 158.7057273562501 -80.44044658324994, 158.6154162567501 -80.4395342484166, 158.5313232533751 -80.44036800074994, 158.45344834612507 -80.44294784024993, 158.37557343887505 -80.44552767974994, 158.29769853162503 -80.44810751924993, 158.21228894400002 -80.43761987999994, 158.11934467600003 -80.41406476199995, 158.10695526625003 -80.39379956062496))',4326),'+proj=rhealpix') AS way)
> SELECT ST_Transform(way,'+proj=rhealpix','+proj=longlat +datum=WGS84 +no_defs +type=crs') FROM test
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231106/50e57c4c/attachment.htm>
