[postgis-users] Extracting variable information from netcdf, imported as raster to a table
Manaswini Ganjam manu.ganjam at gmail.com
Thu Nov 16 10:18:31 PST 2023
Thank you, Regina,
I apologize, I have shared the older version of my code, I have tried
ST_pixelascentroid and ST_value and the issue was I messed up the
parameters of centroids and that caused the errors now I corrected that as
well. I think the code below is a good representation of my approach, I
would like to iterate for every raster in a table, for every band and for
every lat and lon and extract st value, and insert it to a table,
psql:/home/manaswini/MEGA/bbgc_uw_rpackage/rproject/raster2pgsql/extract_table_queryyyy.sql:66:
NOTICE:  Invalid band index (must use 1-based). Returning empty set for all
the coordinates and bands. What could be the issue.
Is this because my data is packed? the readme file of the data has this
information: Details about the data packing:
The data has been packed into short integers (2 bytes instead of 4
byte reals) to save space. You must unpack that data to get the
correct floating point representation of the data. Each netCDF
variable that has been packed has an add_offset and scale_factor
attribute associated with it. Some software automatically unpacks the
data when it is read.
The formula to unpack the data is:
unpacked value = add_offset + ( (packed value) * scale_factor )
For more information see
here:https://www.unidata.ucar.edu/software/netcdf/workshops/2010/bestpractices/Packing.html
There's also another attribute called "missing_value". In this case
all the -32768 values you see are missing. Only the grid points
outside the downscaling domain is given the missing data value.
The packing saves a lot of space, that is why the data is packed.
-- Create the precipitation_temperature_data table
DROP TABLE IF EXISTS extracted_data_bbox;
CREATE TABLE extracted_data_bbox (
    id SERIAL PRIMARY KEY,
    year integer,
    year_day integer,
    lat double precision,
    lon double precision,
    prcp double precision,
    tmax double precision,
    tmin double precision,
    observation_time timestamp
-- Loop through all records in gfdl_03_bbox
DO $$
DECLARE
    raster_record RECORD;
    year_from_filename integer;
    observation_time timestamp;
    centroid_point geometry;
    variable_name text;
    variable_value double precision;
    band_number integer;
    band_numbers integer[];
    pixel_data RECORD;
BEGIN
    FOR raster_record IN (SELECT * FROM gfdl_03_bbox) LOOP
        SELECT regexp_replace(raster_record.filename, '.*_(\d{4})[^0-9]+',
'\1')::integer INTO year_from_filename;
        -- Determine the variable name based on the filename
        IF raster_record.filename ~ 'prcp' THEN
            variable_name := 'prcp';
        ELSIF raster_record.filename ~ 'tmax' THEN
            variable_name := 'tmax';
        ELSIF raster_record.filename ~ 'tmin' THEN
            variable_name := 'tmin';
        ELSE
            RAISE EXCEPTION 'Unknown variable in filename: %',
raster_record.filename;
        END IF;
        band_numbers := ARRAY(SELECT generate_series(1, 366));
        -- Loop through all bands within the file
        FOREACH band_number IN ARRAY band_numbers LOOP
            -- Print the band number to the PostgreSQL log
            RAISE NOTICE 'Band Number: %', band_number;
            observation_time := MAKE_DATE(year_from_filename, 1, 1) +
(band_number - 1) * interval '1 day';
            SELECT * FROM ST_PixelAsCentroids(raster_record.clipped_raster,
band_number, true) INTO pixel_data;
            -- Extract the centroid point from pixel_data
            centroid_point := pixel_data.geom;
            -- Extract the variable value based on the variable name
            EXECUTE format('SELECT ST_Value($1, $2, $3, true)',
raster_record.clipped_raster, band_number, centroid_point) INTO
variable_value USING raster_record.clipped_raster, band_number,
centroid_point;
            -- Insert the extracted data into the extracted_data_bbox table
            INSERT INTO extracted_data_bbox (year, year_day, lat, lon,
prcp, tmax, tmin, observation_time)
            VALUES (year_from_filename, band_number, ST_Y(centroid_point),
ST_X(centroid_point), CASE WHEN variable_name = 'prcp' THEN variable_value
ELSE NULL END,
                    CASE WHEN variable_name = 'tmax' THEN variable_value
ELSE NULL END,
                    CASE WHEN variable_name = 'tmin' THEN variable_value
ELSE NULL END, observation_time);
        END LOOP;
    END LOOP;
END;
I have tried the following query to check values for a raster band : the
output is again null
psql:/home/manaswini/MEGA/bbgc_uw_rpackage/rproject/raster2pgsql/test_query_fff.sql:22:
NOTICE:  Band: 20, X: 1, Y: 135, Value: <NULL>
DO $$
DECLARE
    band_number integer := 20; -- Replace with the desired band number
    x_coord integer;
    y_coord integer;
    pixel_value double precision;
    srid integer := 4326; -- Replace with the correct SRID for your data
BEGIN
    -- Loop through all x and y coordinates in the raster band
    FOR x_coord IN (SELECT generate_series(1,
ST_Width(rast.clipped_raster)) FROM gfdl_03_bbox AS rast WHERE
rast.filename = 'prcp_03_2034.nc') LOOP
        FOR y_coord IN (SELECT generate_series(1,
ST_Height(rast.clipped_raster)) FROM gfdl_03_bbox AS rast WHERE
            -- Get the pixel value at the current x and y coordinates
            SELECT ST_Value(ST_SetSRID(rast.clipped_raster, srid),
band_number, ST_SetSRID(ST_Point(x_coord, y_coord), srid)) INTO pixel_value
            WHERE rast.filename = 'prcp_03_2034.nc';
            -- Print or use the pixel value as needed
            RAISE NOTICE 'Band: %, X: %, Y: %, Value: %', band_number,
x_coord, y_coord, pixel_value;
        END LOOP;
    END LOOP;
END;
Thank you,
Manaswini
On Wed, 15 Nov 2023 at 20:42, Regina Obe <lr at pcorp.us> wrote:
> I didn’t realize that netCDF also has a vector component.
> https://gdal.org/drivers/vector/netcdf.html#vector-netcdf
> To read the vector component, you’d use the ogr_fdw extension to read that
> rather than postgis_raster extension.
> Details here -  https://github.com/pramsey/pgsql-ogr-fdw
> So perhaps that is what your python is doing reading the vector
> component.  I don’t know if netcdf mixes those in one data set or not since
> I have no experience using netcdf.
> I recall you said you are using the OSGeo Live 16 distribution.  I just
> checked the OSGeoLive 16 does include ogr_fdw
> So do
> CREATE EXTENSION ogr_fdw;
> The list of supported formats you can see with this query:
> SELECT name FROM unnest(ogr_fdw_drivers()) AS f(name) ORDER BY name;
> Which for osgeolive 16, I see netCDF listed
> *From:* Regina Obe <lr at pcorp.us>
> *Sent:* Wednesday, November 15, 2023 6:19 PM
> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> *Cc:* 'Manaswini Ganjam' <manu.ganjam at gmail.com>
> *Subject:* RE: [postgis-users] Extracting variable information from
> Just confirming some stuff, since I’m not completely following:
> Raster_record.rast column is of type raster correct?  IF so ST_X and ST_Y
> won’t work since those are for geometry types.
> Also ST_Value(raster_record.rast, band_number), won’t work either since
> that expects as input a geometry or x,y on the raster you want the value
> you.
> I would think you would have gotten an error with that, which makes me
> feel I’m missing something critical.
> If you want to extract all the pixels in a raster, you’d do something like
> https://postgis.net/docs/RT_ST_PixelAsPoints.html
> SELECT pp.x, pp.y, pp.val, ST_X(pp.geom) AS lon, ST_Y(pp.geom) AS lat
> FROM raster_record,
> ST_PixelAsPoints(raster_record.rast, 1) AS pp
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Manaswini Ganjam via postgis-users
> *Sent:* Wednesday, November 15, 2023 2:01 PM
> *To:* postgis-users at lists.osgeo.org
> *Cc:* Manaswini Ganjam <manu.ganjam at gmail.com>
> *Subject:* [postgis-users] Extracting variable information from netcdf,
> Hi,
> I have been trying to download s3 cloud stored gridded climate data and
> generate tables with variables, lat, lon and timestamp (year, yearday). To
> achieve this I used raster2pgsql and imported multiple netcdf files into a
> database table.
> Question: How to achieve the extraction of variables using postgis? I
> tried using ST_value, ST_pixelaspoints but I was getting errors, mainly due
> to the format in which netcdfs are stored in the database (the error says
> can't load some characters like 00E30100082...), I even tried changing
> the datatype to float but still did not work. I mean it is probably not
> simple like selecting a variable from the netcdf. I have enclosed my sql
> query below:
>   -- Iterate through all raster files in the table
>     FOR raster_record IN (SELECT * FROM gfdl_03_prcp) LOOP
>         -- Determine the year from the raster file name, assuming the
> format is 'prcp_03_1950.nc'
>         SELECT
>             regexp_replace(raster_record.filename, '.*_(\d{4})\.nc',
> '\1')::integer
>         INTO
>             year;
>         -- Calculate the start date of the year
>         year_start := (year || '-01-01')::date;
>         -- Determine if the year is a leap year
>         is_leap_year := EXTRACT(ISODOW FROM (year_start + interval '1
> year')) = 7;
>         -- Set the number of bands for the year (365 for non-leap years,
> 366 for leap years)
>         FOR band_number IN 1..(CASE WHEN is_leap_year THEN 366 ELSE 365
> END) LOOP
>             -- Calculate the observation_time using the year and band
> number
>             observation_time := year_start + (band_number - 1) * interval
> '1 day';
>             -- Extract X (lon) and Y (lat) coordinates from the raster
>             SELECT
>                 ST_X(raster_record.rast) AS lon,
>                 ST_Y(raster_record.rast) AS lat
>             INTO
>                 lon,
>                 lat;
>             -- Insert the lat, lon, prcp, and observation_time into the
> extracted_values table
>             INSERT INTO extracted_values (lat, lon, prcp, observation_time)
>             VALUES
>                 (lat, lon, ST_Value(raster_record.rast, band_number),
> observation_time);
>             -- Increment the counter
>             counter := counter + 1;
>             -- Commit the transaction periodically in batches
>             IF counter % batch_size = 0 THEN
>                 COMMIT;
>             END IF;
>         END LOOP;
>     END LOOP;
> The metadata for the two files is as follows:
> File from database:
> {'NC_GLOBAL#Conventions': 'CF-1.5',
>  'NC_GLOBAL#GDAL': 'GDAL 3.6.4, released 2023/04/17',
>  'NC_GLOBAL#history': 'Wed Nov 15 13:32:13 2023: GDAL CreateCopy( not_clipped_prcp.nc, ... )'}
> File before loading into the database:
> {'lat#units': 'degrees_north',
>  'lon#units': 'degrees_east',
>  'NC_GLOBAL#title': 'Daily statistically downscaled CMIP5 data for the United States and southern Canada east of the Rocky Mountains, version 1.0, realization 1, 0.1x0.1 degree spatial resolution.',
>  'NETCDF_DIM_EXTRA': '{time}',
>  'NETCDF_DIM_time_DEF': '{366,4}',
>  'NETCDF_DIM_time_VALUES': '{0,1,2,3,4,5,6,7,8,9,10,11,12,13,14....362,363,364,365}',
>  'prcp#add_offset': '819.17499',
>  'prcp#long_name': 'daily precipitation accumulation',
>  'prcp#missing_value': '-32768',
>  'prcp#scale_factor': '0.025',
>  'prcp#units': 'mm',
>  'prcp#_FillValue': '-32768',
>  'time#units': 'days since 1952-1-1 0:0:0.0'}
> In case this information is useful: Previously I used python to extract variable information and generate a csv or table using this variable information, and the code is enclosed below. In the code I extracted variable values using lon = dataset.variables['lon'][:] and iterated for loops to write them all in csv.
> Python code:
> import netCDF4 as nc
> # Step 1: Read the NetCDF file
> filename = "/home/manaswini/prcp_03_1950.nc"
> dataset = nc.Dataset(filename)
> dataset.set_auto_mask(False)
> dataset.set_auto_scale(True)
> lat = dataset.variables['lat'][:]
> time = dataset.variables['time'][:]
> prcp = dataset.variables['prcp'][:]
> import numpy as np
> import csv
> # csv_buffer
> csv_buffer = open('output.csv', 'w', newline='')
> csv_writer = csv.writer(csv_buffer)
> # Iterate through grid points and write to CSV buffer
> for i in enumerate(lon):
>     for j in enumerate(lat):
>         for k in enumerate(time):
>          csv_writer.writerow([lat[j], lon[i], prcp[i][j][k], year[k],
> yearday[k]])
> # Close the CSV buffer
> csv_buffer.close()
> Thank you,
> Manaswini Ganjam
Manaswini Ganjam
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231116/5f158550/attachment.htm>
