[postgis-users] strange behavior in ST_SnaptoGrid
Paul Ramsey pramsey at cleverelephant.ca
Sun Sep 3 16:29:39 PDT 2023
One thing to always ask is “why exactly am I doing this snapping operation?”
If the answer is “so my numbers look nicer in my UI” then using the second parameter of the ST_AsText() function will give you nice, perfectly rounded-looking outputs just like you want them.
ATB,
P
> On Sep 3, 2023, at 3:07 PM, Mike Taves <mwtoews at gmail.com> wrote:
> On Mon, 4 Sept 2023 at 00:06, Sajjad Hassany Pazoky
> <ijustloveit13 at gmail.com> wrote:
>> I observed a strange behavior when using ST_SnaptoGrid.
>> I don't know whether I am making a mistake or if there is a bug.
>> The following code:
>> SELECT ST_AsText(ST_SnapToGrid(
>>        ST_GeomFromText('LINESTRING(334729.13 4103548.88,334729.12 4103548.53)'),
>>        0.001)
>> produces:
>> LINESTRING(334729.13 4103548.88,334729.12 4103548.5300000003)
> This is an annoying quirk of floating point numbers. What is happening
> behind the scenes is simple:
> value = 4103548.53
> grid = 0.001
> snapped = round(value / grid) * grid
> which results with 4103548.5300000003 which is one floating point unit
> too many! There is a nextafter C function that could be used to bring
> the result down a notch. Using Python/NumPy the example would be:
> np.nextafter(np.rint(value / grid) * grid, -np.inf)
> But it's difficult to know when to increment/decrement the float by a
> small amount, and which direction. There is a better solution
> somewhere, but I haven't figured it out yet.
> Note that the actual source code for PostGIS' implementation is:
> https://github.com/postgis/postgis/blob/11876ebb5e70dfb3c1b40e48bfc343820e6000d9/liblwgeom/ptarray.c#L2082-L2155
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
