[postgis-users] ERROR: extension "postgis" has no update path from version "3.2.1" to version "3.2.0"
Bo Guo bo.guo at gisticinc.com
Tue Sep 5 05:52:36 PDT 2023
Hi, Regina!
I do not know why the new stall Postgresql 14 with Postgis-3 on the newly
built Ubuntu server 22.04 would have Postgis 3.2.0.  This was the command I
used for the postgis install:
   sudo apt install postgresql-14-postgis-3
I went to the postgis folder (/usr/share/postgresql/14/extension) but could
ONLY see files with version of 3.2.0 and lower.  So it appeared that the
installation did not bring postgis to the 3.2.1 or above.  Please let me
know alternative ways to install higher version.
Cheers,
Bo
On Mon, Sep 4, 2023 at 5:06 PM Regina Obe <lr at pcorp.us> wrote:
> Bo,
> At a glance, it looks like maybe your PostgreSQL 13 had a 3.2.1 installed
> and your PostgreSQL 14 has 3.2.0 installed (or at least the postgis.control
> file probably has 3.2.0 instead of 3.2.1).
> I’d double check to make sure you did install 3.2.1 on your PostgreSQL
> 14.  Downgrades are not supported which is essentially what it’s telling
> you.
> That said, the preferable way for upgrading PostGIS 3 is to use:
> SELECT postgis_extensions_upgrade();
> Though that will probably result in the same error since it seems your
> PostgreSQL 14 is running with 3.2.0 instead of 3.2.1.
> The ALTER EXTENSION approach has a couple of downsides, that
> postgis_extensions_upgrade can handle
>    1. It will only update postgis and not your other extensions like for
>    example your postgis_topology.  Postgis_extensions_upgrade()  will upgrade
>    any postgis_ extension.
>    2. If you are moving from a PostgreSQL major to another PostgreSQL
>    major on same version, you still need to upgrade, but because  ALTER
>    EXTENSION relies on a version bump, it won’t be able to upgrade.
> If you still see a mismatch after please let us know.  I know we’ve made
> improvements in postgis_extensions_upgrade so 3.2.0 might not have all the
> new features.
> Thanks,
> Regina
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Bo Guo
> *Sent:* Monday, September 4, 2023 7:40 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] ERROR: extension "postgis" has no update path
> Hi all,
> I do not know how it happened, but after I upgraded from Postgresql 13-
> 14, I had a problem updating extensions, including postgis by using:
> ALTER EXTENSION "postgis" UPDATE;
> Here is the version info:
> SELECT version();
> PostgreSQL 14.9 (Ubuntu 14.9-0ubuntu0.22.04.1) on x86_64-pc-linux-gnu,
> compiled by gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
> SELECT postgis_full_version();
> POSTGIS="3.2.0 c3e3cc0" [EXTENSION] PGSQL="130" (procs need upgrade for
> use with PostgreSQL "140") GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1"
> LIBXML="2.9.12" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
> (core procs from "3.2.1 5fae8e5" need upgrade) TOPOLOGY (topology procs
> I really appreciate any help you can provide.
> Bo
> *Bo Guo**, PhD, PE*
> President
> 2820 S Alma School Rd #18-671, Chandler, AZ 85286
> p 480-656-9962     c 602-570-4697
> *www.gisticinc.com <http://www.gisticinc.com>*
> *youtube.com/linearbench <http://youtube.com/linearbench>*
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230905/5bd5e36b/attachment.htm>
