[postgis-users] ERROR: extension "postgis" has no update path from version "3.2.1" to version "3.2.0"
Regina Obe lr at pcorp.us
Wed Sep 6 07:56:13 PDT 2023
No.  Well not advisable.  People have run into a lot of issues, primarily around PROJ dependency.
The other reason why you might not want to is because most PostGIS dependency checks are done at runtime.
This isn’t an issue for GDAL so much, but more for GEOS.
So even though UbuntuGIS generally ships with a newer GEOS than main ubuntu repos, just because it says say GEOS 3.11, PostGIS will still only allow you to use functions allowed for the GEOS that apt postgresql org was compiled with.
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Gandalf the Gray
Sent: Wednesday, September 6, 2023 6:38 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] ERROR: extension "postgis" has no update path from version "3.2.1" to version "3.2.0"
Hi guys
Sorry to hijack this thread a bit, but my question is very similar.
Is it possible to use PostGIS from the postgresql apt repo, while using gdal etc (for qgis and grass) from ubuntugis-unstable ppa?
Pieter
On Tue, Sep 5, 2023 at 4:00 PM Bo Guo <bo.guo at gisticinc.com <mailto:bo.guo at gisticinc.com> > wrote:
Hi, Regina!  I solved the problem.
It turned out I missed the step of "Adds pgdg keys and main repo" as referenced in https://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS3UbuntuPGSQLApt
Thank you again!
Bo
On Tue, Sep 5, 2023 at 5:52 AM Bo Guo <bo.guo at gisticinc.com <mailto:bo.guo at gisticinc.com> > wrote:
Hi, Regina!
I do not know why the new stall Postgresql 14 with Postgis-3 on the newly built Ubuntu server 22.04 would have Postgis 3.2.0.  This was the command I used for the postgis install:
   sudo apt install postgresql-14-postgis-3
I went to the postgis folder (/usr/share/postgresql/14/extension) but could ONLY see files with version of 3.2.0 and lower.  So it appeared that the installation did not bring postgis to the 3.2.1 or above.  Please let me know alternative ways to install higher version.
Cheers,
Bo
On Mon, Sep 4, 2023 at 5:06 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Bo,
At a glance, it looks like maybe your PostgreSQL 13 had a 3.2.1 installed and your PostgreSQL 14 has 3.2.0 installed (or at least the postgis.control file probably has 3.2.0 instead of 3.2.1).
I’d double check to make sure you did install 3.2.1 on your PostgreSQL 14.  Downgrades are not supported which is essentially what it’s telling you.
That said, the preferable way for upgrading PostGIS 3 is to use:
SELECT postgis_extensions_upgrade();
Though that will probably result in the same error since it seems your PostgreSQL 14 is running with 3.2.0 instead of 3.2.1.
The ALTER EXTENSION approach has a couple of downsides, that postgis_extensions_upgrade can handle
1.	It will only update postgis and not your other extensions like for example your postgis_topology.  Postgis_extensions_upgrade()  will upgrade any postgis_ extension.
2.	If you are moving from a PostgreSQL major to another PostgreSQL major on same version, you still need to upgrade, but because  ALTER EXTENSION relies on a version bump, it won’t be able to upgrade.
If you still see a mismatch after please let us know.  I know we’ve made improvements in postgis_extensions_upgrade so 3.2.0 might not have all the new features.
Thanks,
Regina
From: postgis-users <postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> > On Behalf Of Bo Guo
Sent: Monday, September 4, 2023 7:40 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Subject: [postgis-users] ERROR: extension "postgis" has no update path from version "3.2.1" to version "3.2.0"
Hi all,
I do not know how it happened, but after I upgraded from Postgresql 13- 14, I had a problem updating extensions, including postgis by using:
ALTER EXTENSION "postgis" UPDATE;
Here is the version info:
SELECT version();
PostgreSQL 14.9 (Ubuntu 14.9-0ubuntu0.22.04.1) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
SELECT postgis_full_version();
POSTGIS="3.2.0 c3e3cc0" [EXTENSION] PGSQL="130" (procs need upgrade for use with PostgreSQL "140") GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1" LIBXML="2.9.12" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" (core procs from "3.2.1 5fae8e5" need upgrade) TOPOLOGY (topology procs from "3.2.1 5fae8e5" need upgrade)
I really appreciate any help you can provide.
Bo
Bo Guo, PhD, PE
President
  <https://gisticinc.com/wp-content/uploads/2019/03/GLogoSquareName.png>
2820 S Alma School Rd #18-671, Chandler, AZ 85286
p 480-656-9962     c 602-570-4697
www.gisticinc.com <http://www.gisticinc.com>
youtube.com/linearbench <http://youtube.com/linearbench>
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230906/66eb4ed1/attachment.htm>
