[postgis-users] generate a geometry column of random point, line and polygon
Shaozhong SHI shishaozhong at gmail.com
Fri Sep 8 07:54:27 PDT 2023
The simplicity is beautiful.  Any simple script to do so?  I think that
will be an useful addition.
Regards,
David
On Friday, 8 September 2023, Regina Obe <lr at pcorp.us> wrote:
> David,
> For this are you needing to generate random points from a line or polygon
> or are you trying to generate random polygons, lines, and points?
> If you need to generate random points from a polygon:
> Use ST_GeneratePoints:  https://postgis.net/docs/en/ST_GeneratePoints.html
> Note there is a option seed argument, that will give you the same exact
> answer if you give it the same seed, but without that the generated points
> will be different each time.
> As I recall, ST_GeneratePoints only works with areals so won’t work with a
> line, however you can buffer a line very thinly to do the same. Use a flat
> buffer:
> https://postgis.net/docs/en/ST_Buffer.html
> SELECT ST_GeneratePoints(ST_Buffer(
> ST_GeomFromText(
>   'LINESTRING(50 50,150 150,150 50)'
> ), 0.5, 'endcap=square join=round'), 1000);
> If you want to generate random polygons, you could use ST_ConcaveHull or
> ST_AlphaShape around the section of a polygon you did a ST_GeneratePoints on
> And then use something like https://postgis.net/docs/en/ST_Subdivide.html
> to chop up the polygons.
> To get a linestring out of that (It will be closed), you can take the
> boundary of any of the above
> https://postgis.net/docs/ST_Boundary.html
> Hope that helps,
> Regina
> *From:* postgis-users <postgis-users-bounces at lists.osgeo.org> *On Behalf
> Of *Shaozhong SHI
> *Sent:* Friday, September 8, 2023 7:56 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] generate a geometry column of random point,
> line and polygon
> Is a simple way to do this?
> Regards,
> David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230908/17a2c937/attachment.htm>
