[postgis-users] ArcGIS Online without ArcGIS server
Regina Obe lr at pcorp.us
Sat Sep 16 03:21:47 PDT 2023
Thanks everyone who chimed in on this.  It’s sad to hear but it is what it is.
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Marcelo Marques
Sent: Friday, September 15, 2023 1:59 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] ArcGIS Online without ArcGIS server
Hello,
The answer is "No". ArcGIS Online is not able to connect to a PostGIS enabled database directly.
ArcGIS Online is a SAS Software As a Service, and you need to store your data into the ArcGIS Online Feature Data Store.
Data Management in ArcGIS Online - https://doc.arcgis.com/en/arcgis-online/manage-data/data-in-online.htm
FAQ ArcGIS Online - https://doc.arcgis.com/en/arcgis-online/reference/faq.htm
However as mentioned ArcGIS Online allows you to Add a Service from a URL.
https://doc.arcgis.com/en/arcgis-online/manage-data/add-item-from-url.htm
This means if you have an ArcGIS Geodatabase on PostgreSQL you can store the spatial data with esri st_geometry or with postgis pg_geometry.
Then with ArcGIS Server you can publish a Map Service or Feature Service using the layer or layers from the PostgreSQL Geodatabase.
Then, you can use the Map Service / Feature Service URL with ArcGIS Online.
The ArcGIS Server VM and PostgreSQL Geodatabase can reside in the Cloud, e.g. Amazon or Azure.
I hope this clarifies.
Thanks,
| Marcelo Marques | Esri PS Products | Principal Product Engineer |
| Cloud & Database Administrator | OCP – Oracle Certified Professional |
| Esri | 380 New York St | Redlands, CA 92373 | USA |
| T +909-369-1787 | M +909-255-2079 |  <http://esri.com/> esri.com |
 | Esri Enterprise Mapping and Charting Databases Best Practices <https://community.esri.com/groups/mapping-and-charting-enterprise-databases/blog/2014/12/18/enterprise-mcs-databases-best-practices>  |
|  <https://www.linkedin.com/in/mmarquesbr/> https://www.linkedin.com/in/mmarquesbr/ |
On Fri, Sep 15, 2023 at 9:20 AM Phil Bartie <philbartie at gmail.com <mailto:philbartie at gmail.com> > wrote:
ArcGIS online supports WMS, WMTS, and WFS OGC web services.
Best,
Phil
On Fri, 15 Sept 2023 at 16:43, Martin Davis <mtnclimb at gmail.com <mailto:mtnclimb at gmail.com> > wrote:
It's my educated guess that the answer is no.  The AGOL client talks via web services to the backend, so it can't talk directly to a database server.
It *might* be able to talk to a non-AGOL web service (probably using OGC protocols)?
On Fri, Sep 15, 2023 at 8:26 AM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
This may be a question to just people using ArcGIS Online or at least
familiar with it.  Is it possible to have an ArcGIS online connect to a
PostGIS enabled database (assuming you have the port open etc), without an
ArcGIS Server license?
If so are their limitations in terms of what features you can use of ArcGIS
Online like their javascript apis etc?
Thanks,
Regina
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230916/1e748337/attachment.htm>
