GDAL dependencies during PostGIS upgrade
Nikhil Shetty nikhil.dba04 at gmail.com
Thu Feb 15 21:46:20 PST 2024
Hi Regina,
We are upgrading from PG 13 3.1.2  to  PG 15 3.3.5
I forget if pg_upgrade checks the old .so to see if it can still load it or
> if it only checks if the new .so it is expecting in the new cluster is
> still available.
pg_upgrade is checking in the PG13 lib whether the .so file exists or not.
If it does check, I’d try upgrading to a newer PostGIS on your older
> cluster, doesn’t need to be the same, just one where the gdals are
> compatible.
We might have to go with this approach because it checks the .so file in
old version
Error:
pg_dump: error: query failed: ERROR:  could not access file
"$libdir/postgis-3": No such file or directory
pg_dump: detail: Query was: EXECUTE dumpFunc('23873')
Missing .so files:
-0-root at host:/usr/pgsql-13/lib # ls -l /usr/pgsql-13/lib/postgis*
ls: cannot access '/usr/pgsql-13/lib/postgis*': No such file or directory
-2-root at host:/usr/pgsql-13/lib # ls -l /usr/pgsql-15/lib/postgis*
/usr/pgsql-15/lib/postgis-3.so
/usr/pgsql-15/lib/postgis_raster-3.so
/usr/pgsql-15/lib/postgis_sfcgal-3.so
/usr/pgsql-15/lib/postgis_topology-3.so
Thanks,
Nikhil
On Fri, Feb 16, 2024 at 10:53 AM Regina Obe <lr at pcorp.us> wrote:
> Nikhil,
> Which version of PostgreSQL are you upgrading from.
> or if it only checks if the new .so it is expecting in the new cluster is
> still available.
> If it doesn’t check the old to try to load the lib, dropping postgis-3.1.2
> should work just fine.
> Since 3.0, the .so file didn’t change, so pg_upgrading from say a PG 13
> 3.1.2 to a PG 15 3.3.5 should work just fine.
> compatible.
> *From:* Nikhil Shetty <nikhil.dba04 at gmail.com>
> *Sent:* Thursday, February 15, 2024 11:37 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* GDAL dependencies during PostGIS upgrade
> Hi Team,
> We are planning to upgrade postgres to 15 and postgis from 3.1.2 to 3.3.5.
> While installing postgis 3.3.5 we found some dependency issues with
> gdal36, we were able to workaround by removing postgis 3.1.2 and gdal32
> packages but for postgres upgrade we need both postgis (3.1.2 and 3.3.5)
> packages to be present.
> Below is the issue when installing gdal36 which is required for postgis
> 3.3.5
> -0-root@<host1>:/tmp # yum install
> gdal36-libs-3.6.4-6PGDG.rhel8.x86_64.rpm
> Last metadata expiration check: 0:00:58 ago on Wed 31 Jan 2024 02:01:35 PM
> UTC.
> Error:
> Problem: problem with installed package gdal32-libs-3.2.3-1.rhel8.x86_64
> - package gdal32-libs-3.2.3-1.rhel8.x86_64 requires
> libarmadillo.so.9()(64bit), but none of the providers can be installed
> - package gdal32-libs-3.2.2-13.rhel8.x86_64 requires
> - cannot install both armadillo-12.6.6-1.el8.x86_64 and
> armadillo-9.700.2-1.el8.x86_64
> - cannot install both armadillo-9.700.2-1.el8.x86_64 and
> - package gdal36-libs-3.6.4-6PGDG.rhel8.x86_64 requires
> libarmadillo.so.12()(64bit), but none of the providers can be installed
> - conflicting requests
> (try to add '—allowerasing' to command line to replace conflicting
> packages or '—skip-broken' to skip uninstallable packages or '—nobest' to
> use not only best candidate packages)
> Thanks,
> Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240216/808e5fa4/attachment.htm>
