PostGIS performance issue
Regina Obe lr at pcorp.us
Thu Feb 22 06:38:35 PST 2024
Possible or one of the dependencies is different, or planner differences such as the CTE changes that came in PostgreSQL 12, but hard to tell given the information you have provided
Or you didn’t reindex your data after the upgrade to a newer version of PostgreSQL and such a reindex was required.
I have had to change some of my CTEs queries after upgrading to PostgreSQL 12+ to get back to same speed or better as prior runs for example.
First of all?
What does the below return now (and if you can remember the key bits like GEOS, PROJ, PostgreSQL Version what did you have before)
SELECT version(),  postgis_full_version();
Two,  If you can provide the query you are trying to run,  that would help, as we may see a pattern there.
Sent: Thursday, February 22, 2024 9:23 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: PostGIS performance issue
My system has recently been upgraded from Linux 7 to Linux 8.
There are performance issues with PostGIS
"A process used to take 3.9 hours.  Now, it has taken more than 2 days and yet it has not completed running.  No errors have been flagged up."
Is possible the PostGIS not configured properly?
Regards,
David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240222/5d010c31/attachment.htm>
