ST_OrientedEnvelope returning parallelogram
Ricardo Mayerhofer ricardo.ekm at gmail.com
Fri Mar 8 10:35:53 PST 2024
Thanks for the reply! This is my current PostGIS version:
POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="150"
GEOS="3.11.2-CAPI-1.17.2" PROJ="8.0.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/rdsdbbin/postgres-15.5.R1/share/proj/proj.db"
GDAL="GDAL 3.4.3, released 2022/04/22" LIBXML="2.9.1" LIBJSON="0.15"
LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
On Fri, Mar 8, 2024 at 3:30 PM Erik Wienhold <ewie at ewie.name> wrote:
> On 2024-03-07 07:05 +0100, Ricardo Mayerhofer wrote:
> > I have a GIS application with multiple polygons where I'd like to get the
> > rotated bounding box of the polygons. ST_OrientedEnvelope seems to be the
> > right function, but in my case, is returning a parallelogram instead of a
> > rectangle.
> > I've created a simple example where the original polygon is a rectangle
> > just to demonstrate the issue:
> > CREATE TABLE geometries (
> >   geometry geometry
> > INSERT INTO geometries(geometry)
> > values(ST_GeomFromText('POLYGON((-71.25961696926942
> > 42.470522973159675,-71.25978846747648
> > 42.470624424600906,-71.25973918365264
> > 42.47066975346566,-71.25956768540266
> > 42.47056830210077,-71.25961696926942 42.470522973159675))'))
> > SELECT ST_AsGeoJson(st_collect(ST_OrientedEnvelope(geometry),
> > geometry)) FROM geometries
> > [image: Screenshot 2024-03-07 at 02.59.37.png]
> > Image link:
> https://www.dropbox.com/scl/fi/xoi87e06mtfsnc1qzw3wu/oriented_2.png?rlkey=37ajuo6lwdnynk9gi8hpmoolq&dl=0
> > Any help is appreciated, thanks!
> What is your PostGIS and GEOS version?  Please provide the output of
>         SELECT postgis_full_version();
> I can confirm this bug on 3.4.1 with GEOS 3.12.0.  Could be a regression
> in GEOS 3.12.0:
>         "CAPI: GEOSMinimumRotatedRectangle now uses MinimumAreaRectangle
> (Paul Ramsey)" [1]
> [1] https://github.com/libgeos/geos/blob/main/NEWS.md#changes-in-3120
> Erik
Ricardo Mayerhofer
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240308/949390b5/attachment.htm>
