Database crash when creating raster_in function
Nikhil Shetty nikhil.dba04 at gmail.com
Mon Mar 18 09:36:52 PDT 2024
Hi Regina,
I checked the code that we used to build 3.3.5 packages and you are right
the fix is already present  but not sure why we are still getting the error
on PG15.
I will debug and get back to you.
Thanks,
Nikhil
On Mon, Mar 18, 2024 at 1:55 PM Regina Obe <lr at pcorp.us> wrote:
> Most of that fix should already be in the PG15 3.3.5 except for the parts
> that have PG16 guards, cause they wouldn’t work in PG15 or lower.
> So If you find trying to reapply to 3.3.5 works I’d be surprised and be
> interested in which portion of patch you applied.
> *From:* Nikhil Shetty <nikhil.dba04 at gmail.com>
> *Sent:* Sunday, March 17, 2024 9:49 AM
> *To:* Regina Obe <lr at pcorp.us>
> *Cc:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: Database crash when creating raster_in function
> I am  are using raster extension
> The creation of raster_in function breaks on PG15 as well, JFYI, I have
> created package for 3.3.5 on rhel7(this is not available in Postgres repo)
> Will the fix given in
>  https://trac.osgeo.org/postgis/ticket/5277
>  solve the issue? if yes, I can add the same fix and create new rpms for
> 3.3.5 on rhel7
> Thanks,
> Nikhil
> On Sun, 17 Mar 2024 at 10:07, Regina Obe <lr at pcorp.us> wrote:
> Yap that was fixed in PostGIS 3.3.3.
> The change there was to support a change in PG16, so you shouldn’t need it
> for upgrading from PG13 to PG15.
> Are you using postgis_raster or you just have it installed?
> If you don’t need postgis_raster, I would suggest uninstalling it before
> upgrading.
> *Sent:* Saturday, March 16, 2024 10:55 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Database crash when creating raster_in function
> Hi Team,
> I am trying to upgrade the postgres database from PG13 to PG15. pg_upgrade
> is crashing with below error when creating the raster_in function
> pg_restore: creating FUNCTION "public.raster_in("cstring")"
> pg_restore: while PROCESSING TOC:
> pg_restore: from TOC entry 394; 1255 16439 FUNCTION raster_in("cstring")
> postgres
> pg_restore: error: could not execute query: server closed the connection
> unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> Command was: CREATE FUNCTION "public"."raster_in"("cstring") RETURNS
> "public"."raster"
>     LANGUAGE "c" IMMUTABLE STRICT PARALLEL SAFE
>     AS '$libdir/postgis_raster-3', 'RASTER_in';
> PostGIS version : *3.3.5*
> This looks similar to the issue mentioned in
> https://trac.osgeo.org/postgis/ticket/5277. Is this fixed in 3.3.5 ?
> Thanks,
> Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240318/6dca8919/attachment.htm>
