Running clustering queries
Max Pyziur pyz at brama.com
Wed Mar 27 16:32:59 PDT 2024
On Wed, 27 Mar 2024, Regina Obe wrote:
> That's the function I would have suggested.
> What query are you trying to run and what is the spatial reference system id
> for your data.
> I'm guessing the issue might be your units of measure.  If you want to do
> 500 ft you'd be best using a meter or mile based spatial reference system.
Here are two examples that I tried:
SELECT city, state, ST_ClusterDBScan(geom, eps := 1000, minpoints := 1)
OVER () AS cluster
FROM shapefiles.atp_filling_stations aa
WHERE aa.amenity = 'fuel'
AND aa.ctry_code = 'US' AND aa.geom IS NOT NULL;
SELECT ST_ClusterKMeans(geom, 1000) OVER () as cluster_id
GROUP BY cluster_id;
Neither offers something that seems useful.
Thank you,
Max
>> -----Original Message-----
>> From: Max Pyziur <pyz at brama.com>
>> Sent: Wednesday, March 27, 2024 5:33 PM
>> To: postgis-users at lists.osgeo.org
>> Subject: Running clustering queries
>> Greetings,
>> I have a dataset of filling stations with point geometries (about 80k U.S.
> filling
>> stations)
>> I'm trying to find/make clusters of this data (with a criteria like say
> minimum
>> of 3 stations w/in 500 feet of each other.
>> I've found these webpages; but as yet I can't produce any sort of
> meaningful
>> results.
>> I would appreciate any and all guidence. Thank you.
>> Max Pyziur
>> pyz at brama.com
>> Webpages:
>> Examples Of Spatial Clustering With PostGIS - February 28, 2024
>> https://mapscaping.com/examples-of-spatial-clustering-with-postgis/
>> ST_ClusterDBSCAN
>> https://postgis.net/docs/ST_ClusterDBSCAN.html
>> PostGIS Clustering with DBSCAN | Crunchy Data Blog
>> https://www.crunchydata.com/blog/postgis-clustering-with-dbscan
>> clustering - PostGIS nest ST_ClusterKMeans on results of ST_ClusterKMeans
>> - Geographic Information Systems Stack Exchange
>> https://gis.stackexchange.com/questions/396029/postgis-nest-st-
>> clusterkmeans-on-results-of-st-clusterkmeans
