Continuing on clustering queries
Max Pyziur pyz at brama.com
Thu Mar 28 15:46:13 PDT 2024
On Thu, 28 Mar 2024, Regina Obe wrote:
Thank you to everyone for their contributions here; trying to get to
QGIS visibility here.
[... deleting for the sake of brevity ...]
>> This SQL variant does not return errors, but it isn't visible in my QGIS
> project
>> (it's an ongoing project with about twenty layers built with PostGIS).
>> Any advice?
>> Should I direct this inquiry to the QGIS list?
>> Thank you,
>> Max
> It might be because it returns a geometry collection.  I recall QGIS not
> liking geometry collections.
> Also depending on how you are creating this -- is this a view or an inline
> SQL, you might need to force the type for it to show as a layer option.
Regina: In these subsequent queries you are specifying SRS 4326; shouldn't
it be 2163, the SRS of all of the other layers?
> Try:
>       SELECT cluster_id AS cid1 ,
>       ST_Collect(ST_MinimumBoundingCircle(ST_Collect(geom)),
> ST_Collect(geom))::geometry(GEOMETRYCOLLECTION,4326) AS geom
>       , COUNT(*) as ct FROM shapefiles.filling_station_clusters GROUP BY
>       1;
> Or having as two separate layers:
> -- layer 1
> ST_MinimumBoundingCircle(ST_Collect(geom)):geometry(POLYGON,4326) AS geom
> 1;
> -- layer 2
> SELECT cluster_id AS cid1 ,  ST_Collect(geom):geometry(MULTIPOINT,4326) AS
> geom
> 1;
> Could also be a permission issue.
> If that doesn't help, then yes QGIS mailing list might have more useful
> answers.
> Hope this helps,
> Regina
Thank you again, I'll port these QGIS visibility questions to the QGIS
users list.
But all of the layers that I load are done using PostGIS. Everything seems
to be much more controllable that way.
Max
