[OSRS-PROJ] proj binary coordinates: radians or degrees?
Frank Warmerdam warmerda at home.com
Tue Jul 4 08:54:24 PDT 2000
Folks,
Thomas Knudsen had kindly provided patches for proj to handle binary IO
properly on windows and DOS.  He has also run into the fact that proj binary
coordinate io is in radians, instead of degrees.  Before changing the behaviour
of binary file io to degrees, like formatted results, I wanted to query the
list, and see if anyone anticipates this causing significant hardship.
So, is it OK with everyone if I change the proj commands binary lat/long
coordinates to be in degrees instead of radians?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
