[OSRS-PROJ] Datum Shifting
thk at kms.dk thk at kms.dk
Tue Jul 4 09:19:44 PDT 2000
> proj +proj=latlong +ellps=clrk80 -to +proj=utm +zone=11 +ellps=clrk80
actually I think it would be a good thing to add a "-from" parameter as
well:
this would make the command easier to read, as it resembles everyday
language more:
proj -from .... -to .....
additionally it becomes evident from the first step that we are using the
"new form".
and with the new +proj=latlong option even plain old style conversions
can be stated in a more readable format:
proj -from +proj=utm +zone=32 -to +proj=stere
perhaps it would also be a good idea to introduce a -files flag (or
something
like that: often a plain dash is used to mark "end of options") for the
new form: This way filenames and options are clearly separated, so
the "+" in the beginning of the options (which only serves to distinguish
them from file names) may be made optional, as in the pj_init() call.
If, furthermore,  -from and -to are made equivalent to +proj= the syntax
may
be reduced to:
proj    -from utm zone=32  ellps=grs80    -to utm zone=33    -    infile
outfile
(I assume here that  the ellps setting is inherited from "-from" to "-to"
if
not restated)
I think this form is quite readable, but I may have missed some gotchas...
>This approach ensures we just have one command, and a fairly graceful and
> backward compatible way of going from the current style to the two
coordinate
> system form.  It would also ensure I don't have to duplicate all the
other
> argument handling currently embedded in the proj command.  On the
downside,
> it might be tricky to make the current proj command support Z optional Z
> coordinates without breaking some existing behaviour.
> Do people prefer an approach like the above instead of a new proj2proj
command?
yes - if the syntax is made sufficiently easy to differentiate, while still
being sufficiently close to the original one to be easily understood.
Also, on a different note, I fully second your previous posting on API
additions:
I have really missed the pj_init_1() entry which you suggests. Handling
(the
7 parameter) datum shifts within proj is also a really good thing.
Regards
Thomas
Thomas Knudsen, Research Geophysicist, Ph.D. | http://www.gfy.ku.dk/~tk/
National Survey and Cadastre - Denmark       | thk at kms.dk   tk at gfy.ku.dk
Geodetic Department, Rentemestervej 8        | phone:    +45 35 87 52 64
DK-2400 Copenhagen NV, Denmark               | fax:      +45 35 87 50 52
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
