[OSRS-PROJ] PROJ 4.4.1
Frank Warmerdam warmerda at home.com
Mon Mar 27 08:23:51 PST 2000
Folks,
I have corrected problems with PROJ 4.4.0 's install logic. It wasn't
installing the data files from proj/nad.
In the past these files were installed into /usr/local/lib/proj.4, but using
the default Automake install rules data goes into /usr/local/share/proj.  Does
anyone think this will be a problem?  I am not finding it easy to change
automake's idea of what should happen!
I have also fixed src/Makefile.{in,am} so that PROJ_LIB is defined with the
data path.
The COPYING file has been updated to include an MIT style license.  I would
prefer to not use the LGPL for fear of causing problems with the OGDI users
of PROJ.4 who have been releasing under a non-LGPL OpenSource license.
I have also added a few more links and things to the web page.
I haven't prepared a new tar file yet.  Let me know if someone needs it.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
