[OSRS-PROJ] Support for Transverse Mercator south-oriented projection.
Frank Warmerdam warmerda at home.com
Wed Sep 20 08:26:12 PDT 2000
"Gerald I. Evenden" wrote:
> What do you mean "south oriented projection?"
Jerry,
See the description extracted from the EPSG database:
http://www.remotesensing.org/geotiff/proj_list/transverse_mercator_south_oriented.html
Assuming this isn't directly supported now, how would you suggest handling
it within PROJ.4?  Should a new proj=tmso be implemented that just internally
calls the proj=tm code, and transforms the coordinates appropriately
afterwards?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
