[OSRS-PROJ] Re: PROJ4 Tranverse Mercator South Oriented
Frank Warmerdam warmerda at home.com
Thu Sep 21 12:31:52 PDT 2000
Willem,
Your file:
PCS = 22289 (South African Coordinate System zone 29)
Projection = 17529 (South African Survey Grid zone 29)
Projection Method: CT_TransvMercator_SouthOrientated
   ProjNatOriginLatGeoKey: 0.000000 (  0d 0' 0.00"N)
   ProjNatOriginLongGeoKey: 29.000000 ( 29d 0' 0.00"E)
   ProjScaleAtNatOriginGeoKey: 1.000000
   ProjFalseEastingGeoKey: 0.000000
   ProjFalseNorthingGeoKey: 0.000000
GCS: 4222/Cape
Datum: 6222/Cape
Ellipsoid: 7013/Clarke 1880 (Arc) (6378249.14,6356514.97)
Prime Meridian: 8901/Greenwich (0.000000/  0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
warmerda at cs46980-c[394]% proj +proj=tmerc +lat_0=0 +lon_0=29.0 +k=1.0
+a=6378249.14 +b=6356514.97
26d47'54.95E 26d41'24.59S
-219134.29      -2954952.67
>From the Descartes output:
Image Bottom Right:
PCS: -219134.2379,-2954952.6029
Lat/Long: 26:41:24.59S 26:47:54.95E
Wow!  They are the same!
Conveniently your file has no false easting or northing so there is
no issue with the "sign" of that.  For everything else it almost seems as
if there is no difference between TM and TMSO.  However, I kind of wonder if
this is just that Descartes is just treating TM and TMSO as being the same.
Can you verify if the Descartes corner coordinates in PCS and lat/long
coordinates make sense when compared with the map surround?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerda at home.com
light and sound - activate the windows | http://members.home.com/warmerda
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
