[OSRS-PROJ] Re: Quick 'how-to' to on PROJ.4
Felipe G. Nievinski fnievinski at terra.com.br
Thu Jul 26 16:24:57 PDT 2001
Precedence: bulk
Reply-To: osrs-proj at remotesensing.org
On 26/07/01 at 23:44 Petri J. Riipinen wrote:
>Ok, I almost managed to do it, except that fl_transform returns an error
>code (100)
>GPS-measurements:
>1        6010.570       2455.930      GPS: FINLANDIA-HOUSE
>2        6012.467       2456.127      GPS: RAILWAY YARD
>3        6013.045       2458.826      GPS: VIIKKI MUSEUM
>Do you any idea what might be the problem? Are the values '6010.570' etc in
>correct form for input to pj_transform?
Petri, unfortunately I cannot test your transformation, but these values are not in the standard format. Longitude ranges from -180 to +180 degrees, so, based on Finland's position, 6010.570 seems to be 60 degrees + 10.570 minutes =  60,176 degrees (60+10.570/60). The same for latitude:  2455.930 -> 24d55.930' = 24,932d (What's this, Helsinki?)
Try this.
hope this helps.
Felipe.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
