[OSRS-PROJ] Gauss-Krueger to WGS 84
Mon Jun 18 09:03:06 PDT 2001
Ilja,
I don't know how to related the values you have (like 45589319) to a
coordinate system; however, the list of coordinate systems common in
Germany can be found at:
  http://www.geocities.com/CapeCanaveral/1224/prj/prj.html
If you find that one or more of these is what you need, it should be
possible to use the proj form you show in your email - perhaps which
slight tweaks depending on ellipsoid.
Good luck,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
