[OSRS-PROJ] WGS-1984
Thu Jun 21 05:43:16 PDT 2001
Paul Selormey wrote:
> Hello All,
> This is very basic question, but please bear with me. I have bought two
> books
> on projections so far and still could not find any information on it.
> What is the WGS-1984? and what is its importance with regards to
> projections?
Paul,
There is a datum, and an ellipsoid of this name.  I am not properly trained
in these matters, but the ellipsoid is the shape of the earth, normally
expressed as a major and minor axis, and a datum is a model of various earth
irregularities and survey errors.
WGS84 is a common ellipsoid/datum.  For use with PROJ.4 you would use
this to set the +ellps or +datum parameters after having defined all your
other projection parameters.
The material at the following URL seems like a good overview of datum issues.
  http://www.colorado.edu/geography/gcraft/notes/datum/datum_f.html
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
