[OSRS-PROJ] commercial apps
Hawkswan at aol.com Hawkswan at aol.com
Wed Sep 19 15:02:48 PDT 2001
Mark:
We have been using the original version of Proj.4 in our products for several
years in our C/Unix-based software products.  A couple of years ago, we used
the MKS Nutcracker software development environment to port our products to
PC platforms.  Today, we are completing full conversion and testing of our
products into native MS/C++/MFC versions for PC's.
>From the beginning, Proj.4 worked as advertised, and we had very few problems
with the library.  Programmer interface documentation was not real good, but
enough to get Proj.4 working in our products. Gerald Evenden personally
provided good support when needed, along with lots of great nostalgia.  Our
prior experience was with GCTP, and we knew we didn't want to use that in our
products.
With MKS, the original C/Unix source codes were compiled pretty much as is,
including the Proj.4 library.  We mostly had problems setting up the X-Server
part of NutCracker, but once those were solved, everything worked fine.  If
you are a Unix person, MKS provides all major Unix functionality on a PC,
concurrent with MS Windows, which is nice.
We've had no formal training in using Visual C++/MFC, but got most of our new
software working recently, except for integrating Proj.4.  We first tried to
build the old library and integrate that into our products, but ran into a
lot of problems that, with our lack of VCC experience, we couldn't easily
solve.
After a little research, we realized there were newer versions of Proj.4
available, including a makefile for VC++.  Here, we had two problems: The
first was something about incompatible libraries, causing linking to fail.
The second was that the programmer interface to Proj.4 had changed.
With tons of source code calls to Proj.4, a tight schedule, and what seemed
to be an absence of documentation on the new programmer interfaces, we
decided to tweak the makefile.vc and use that to compile the old library
under VC++.  Surpassingly, it worked, and linked up OK.  All our old Proj.4
calls are functioning correctly.  We still have one little problem with
competing C and VC++ libraries being incompatible in our release version, but
we'll get that worked out.
Our software products primarily support production mosaicking,
transformation, quality assurance and keyword header editing of USGS DOQQs,
and are used by the USGS, their contractors and DOQQ users for quality
assurance and mosaicking of those products.  Besides marketing our software
products, we use our mosaicking and transformation software in support of our
in-house production contracts in support of the USGS IP program.
Once we get all our products going with the old Proj.4 we intend to get
smarter with both MS/VC++/MFC and the latest Proj.4 releases, upgrade our
existing products to the latest Proj.4 version, and get on with seriously
delayed new product development and production backlog.
Bottom line is that the old Proj.4 stuff has worked just fine for us in
covering all UTM and SPCS projections over the Continental US.  Proj.4 has a
lot of usage history, reliability and credibility that a do-it-yourself
package would take a long time to acqire and prove.  You also now have this
user support group.
Sorry this is so long.
Jere Swanson
Hawk Imaging Technology
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20010919/bf32fca8/attachment.html>
