[OSRS-PROJ] libproj.so
Thu Apr 11 08:41:33 PDT 2002
Cyril Bonnard wrote:
> I've just done what you said but it failed again  ;( :
> here is the result (see the errors)
> Pixel Size = (30.000000,-30.000000)
> Corner Coordinates:
> ERROR 1: ./gdalinfo: undefined symbol: pj_transform
> ERROR 1: ./gdalinfo: undefined symbol: pj_get_errno_ref
> ERROR 1: Attempt to load libproj.so, but couldn't find pj_transform.
Cyril,
This indicates gdalinfo is finding an old proj.so.  Use the "locate proj.so"
command to find all proj.so files on your systems, and remove all the ones
except the new one you installed.
Good luck,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
