[OSRS-PROJ] Gauss Boaga
Markus Neteler neteler at itc.it
Tue Aug 20 07:43:34 PDT 2002
On Tue, Aug 20, 2002 at 03:15:26PM +0100, Kieron Brown wrote:
> Hello!
> I confess that I have not looked at the library in depth, but was wondering
> whether there
> was support for the Italian projection Gauss Boaga. I have performed a
> source code
> and documentation search and have not found a reference to this system.
Yes, it is possible including datum transformation:
GaussBoaga fuso Est (Rome40/GB/Zone2) to Lat/Long with datum tranformation:
cs2cs +init=epsg:26592 +towgs84=-225,-65,9 +to +proj=latlong +datum=WGS84
GaussBoaga fuso Ovest (Rome40/GB/Zone1) with datum transformation"
cs2cs +init=epsg:26591 +towgs84=-225,-65,9 +to +proj=latlong +datum=WGS84
Hope this helps,
 Markus Neteler
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italy
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
