[OSRS-PROJ] Build problems in CygWin
Matt Matt at terraengine.com
Fri Dec 6 07:55:44 PST 2002
I am attempting to build proj4 in CygWin and am running into an error
that I need help with. I have included the results of my build attempt
along with the resulting makefile.
Any suggestions would be appreciated.
Thanks,
Matt
------- my attempt to build Proj4
Matt Lynch at MATT ~/projects/proj-4.4.4
$ aclocal
$ ./configure
creating cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c checking
whether build environment is sane... yes checking whether make sets
${MAKE}... yes checking for working aclocal... found checking for
working autoconf... found checking for working automake... found
checking for working autoheader... found checking for working
makeinfo... found checking for gcc... gcc checking whether the C
compiler (gcc  ) works... yes checking whether the C compiler (gcc  ) is
a cross-compiler... no checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes checking for a BSD compatible
install... /usr/bin/install -c checking whether ln -s works... yes
checking whether make sets ${MAKE}... (cached) yes checking host system
type... i686-pc-cygwin checking build system type... i686-pc-cygwin
checking for ranlib... ranlib checking for ld used by GCC...
/usr/i686-pc-cygwin/bin/ld.exe checking if the linker
(/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld... yes checking for
BSD-compatible nm... /usr/bin/nm -B updating cache ./config.cache
loading cache ./config.cache within ltconfig checking for object
suffix... o checking for executable suffix... .exe checking for gcc
option to produce PIC... none checking if gcc supports -c -o file.o...
yes checking if gcc supports -c -o file.lo... yes checking if gcc
supports -fno-rtti -fno-exceptions ... yes checking if gcc static flag
-static works... -static checking if the linker
(/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld... yes checking whether the
linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared lib raries...
yes checking command to parse /usr/bin/nm -B output... ok checking how
to hardcode library paths into programs... immediate checking for
/usr/i686-pc-cygwin/bin/ld.exe option to reload object files... -r
checking dynamic linker characteristics... Win32 ld.exe checking if
libtool supports shared libraries... yes checking if package supports
dlls... no checking whether to build shared libraries... no checking
whether to build static libraries... yes checking for objdir... .libs
creating libtool updating cache ./config.cache loading cache
./config.cache checking for exp in -lm... yes checking how to run the C
preprocessor... gcc -E checking for ANSI C header files... yes updating
cache ./config.cache creating ./config.status creating Makefile creating
src/Makefile creating man/Makefile creating man/man1/Makefile creating
man/man3/Makefile creating nad/Makefile creating src/proj_config.h
$ make
cd . && automake --gnu --include-deps Makefile
cd . && autoconf
/bin/sh ./config.status --recheck
running /bin/sh ./configure  --no-create --no-recursion checking for a
BSD-compatible install... /usr/bin/install -c checking whether build
/home/MattLynch/projects/proj-4.4.4/missing: Unknown `--run' option Try
`/home/MattLynch/projects/proj-4.4.4/missing --help' for more
information
configure: WARNING: `missing' script is too old or missing checking for
gawk... gawk checking whether make sets ${MAKE}... yes checking for
gcc... gcc checking for C compiler default output... a.exe checking
whether the C compiler works... yes checking whether we are cross
compiling... no checking for suffix of executables... .exe checking for
suffix of object files... o checking whether we are using the GNU C
compiler... yes checking whether gcc accepts -g... yes checking for gcc
option to accept ANSI C... none needed checking for style of include
used by make... GNU checking dependency style of gcc... none checking
for a BSD-compatible install... /usr/bin/install -c checking whether ln
-s works... yes checking whether make sets ${MAKE}... (cached) yes
checking build system type... i686-pc-cygwin checking host system
type... i686-pc-cygwin checking for ld used by GCC...
checking for BSD-compatible nm... /usr/bin/nm -B checking for a sed that
does not truncate output... /usr/bin/sed checking how to recognise
dependent libraries... file_magic file format pei*-i38
6(.*architecture: i386)?
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... no
checking for stdint.h... no
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes checking
whether g++ accepts -g... yes checking dependency style of g++... none
checking how to run the C++ preprocessor... g++ -E checking the maximum
length of command line arguments... 8192 checking command to parse
/usr/bin/nm -B output from gcc object... ok checking for objdir... .libs
checking for ranlib... ranlib checking for strip... strip checking if
gcc static flag  works... yes checking if gcc supports -fno-rtti
-fno-exceptions... yes checking for gcc option to produce PIC...
checking if gcc supports -c -o file.o... yes checking whether the gcc
linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared  libraries...
yes checking whether -lc should be explicitly linked in... yes checking
how to hardcode library paths into programs... immediate checking
whether stripping libraries is possible... yes checking dynamic linker
characteristics... Win32 ld.exe checking if libtool supports shared
libraries... yes checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking whether the g++ linker (/usr/i686-pc-cygwin/bin/ld.exe)
supports shared  libraries... yes checking for g++ option to produce
PIC... checking if g++ supports -c -o file.o... yes checking whether the
g++ linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared
libraries... yes checking whether -lc should be explicitly linked in...
yes checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes checking dynamic
linker characteristics... Win32 ld.exe checking for exp in -lm... yes
checking for ANSI C header files... (cached) yes
configure: creating ./config.status
cd . \
  && CONFIG_FILES=Makefile CONFIG_HEADERS= /bin/sh ./config.status
config.status: creating Makefile
config.status: executing depfiles commands
Making all in src
make[1]: Entering directory `/home/MattLynch/projects/proj-4.4.4/src'
cd .. \
  && CONFIG_FILES=src/Makefile CONFIG_HEADERS= /bin/sh ./config.status
config.status: creating src/Makefile
make[1]: Leaving directory `/home/MattLynch/projects/proj-4.4.4/src'
/bin/bash ../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I.
-DPROJ_LIB=\
"/usr/local/share/proj\"    -g -O2 -c PJ_aeqd.c
libtool: ltconfig version `' does not match ltmain.sh version `1.3.4'
Fatal configuration error.  See the libtool docs for more information.
make[1]: *** [PJ_aeqd.lo] Error 1
make: *** [all-recursive] Error 1
------- makefile generated
# Makefile.in generated by automake 1.7.1 from Makefile.am.
# Makefile.  Generated from Makefile.in by configure.
# Copyright 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002 # Free
Software Foundation, Inc. # This Makefile.in is free software; the Free
Software Foundation # gives unlimited permission to copy and/or
distribute it, # with or without modifications, as long as this notice
is preserved.
# This program is distributed in the hope that it will be useful, # but
WITHOUT ANY WARRANTY, to the extent permitted by law; without # even the
implied warranty of MERCHANTABILITY or FITNESS FOR A # PARTICULAR
PURPOSE.
srcdir = .
top_srcdir = .
pkgdatadir = $(datadir)/proj
pkglibdir = $(libdir)/proj
pkgincludedir = $(includedir)/proj
top_builddir = .
am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd INSTALL =
/usr/bin/install -c install_sh_DATA = $(install_sh) -c -m 644
install_sh_PROGRAM = $(install_sh) -c install_sh_SCRIPT = $(install_sh)
-c INSTALL_HEADER = $(INSTALL_DATA) transform =
$(program_transform_name) NORMAL_INSTALL = : PRE_INSTALL = :
POST_INSTALL = : NORMAL_UNINSTALL = : PRE_UNINSTALL = : POST_UNINSTALL =
: host_triplet = i686-pc-cygwin ACLOCAL = aclocal-1.7 AMDEP_FALSE = #
AMDEP_TRUE =
AMTAR = tar
AUTOCONF = autoconf
AUTOHEADER = autoheader
AUTOMAKE = automake-1.7
AWK = gawk
CC = gcc
CCDEPMODE = depmode=none
CFLAGS = -g -O2
CPP = gcc -E
CPPFLAGS =
CXX = g++
CXXCPP = g++ -E
CXXDEPMODE = depmode=none
CXXFLAGS = -g -O2
CYGPATH_W = cygpath -w
DEFS = -DHAVE_CONFIG_H
DEPDIR = .deps
ECHO = echo
ECHO_C =
ECHO_N = -n
ECHO_T =
EGREP = grep -E
EXEEXT = .exe
INSTALL_DATA = ${INSTALL} -m 644
INSTALL_PROGRAM = ${INSTALL}
INSTALL_SCRIPT = ${INSTALL}
INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s
LDFLAGS =
LIBS = -lm
LIBTOOL = $(SHELL) $(top_builddir)/libtool
LN_S = ln -s
LTLIBOBJS =
MAKEINFO = makeinfo
OBJEXT = o
PACKAGE = proj
PACKAGE_BUGREPORT =
PACKAGE_NAME =
PACKAGE_STRING =
PACKAGE_TARNAME =
PACKAGE_VERSION =
PATH_SEPARATOR = :
RANLIB = ranlib
SET_MAKE =
SHELL = /bin/bash
STRIP = strip
VERSION = 4.4.4
ac_ct_CC = gcc
ac_ct_CXX = g++
ac_ct_RANLIB = ranlib
ac_ct_STRIP = strip
am__fastdepCC_FALSE =
am__fastdepCC_TRUE = #
am__fastdepCXX_FALSE =
am__fastdepCXX_TRUE = #
am__include = include
am__quote =
bindir = ${exec_prefix}/bin
build = i686-pc-cygwin
build_alias =
build_cpu = i686
build_os = cygwin
build_vendor = pc
datadir = ${prefix}/share
exec_prefix = ${prefix}
host = i686-pc-cygwin
host_alias =
host_cpu = i686
host_os = cygwin
host_vendor = pc
includedir = ${prefix}/include
infodir = ${prefix}/info
install_sh = /home/MattLynch/projects/proj-4.4.4/install-sh
libdir = ${exec_prefix}/lib
libexecdir = ${exec_prefix}/libexec
localstatedir = ${prefix}/var
mandir = ${prefix}/man
oldincludedir = /usr/include
prefix = /usr/local
program_transform_name = s,x,x,
sbindir = ${exec_prefix}/sbin
sharedstatedir = ${prefix}/com
sysconfdir = ${prefix}/etc
target_alias =
SUBDIRS = src man nad
AUTOMAKE_OPTIONS = dist-zip
subdir = .
ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
mkinstalldirs = $(SHELL) $(top_srcdir)/mkinstalldirs CONFIG_HEADER =
$(top_builddir)/src/proj_config.h CONFIG_CLEAN_FILES = DIST_SOURCES =
RECURSIVE_TARGETS = info-recursive dvi-recursive pdf-recursive \
	ps-recursive install-info-recursive uninstall-info-recursive \
	all-recursive install-data-recursive install-exec-recursive \
	installdirs-recursive install-recursive uninstall-recursive \
	check-recursive installcheck-recursive
DIST_COMMON = README AUTHORS COPYING ChangeLog INSTALL Makefile.am \
	Makefile.in NEWS aclocal.m4 config.guess config.sub configure \
	configure.in install-sh ltconfig ltmain.sh missing \
	mkinstalldirs
DIST_SUBDIRS = $(SUBDIRS)
all: all-recursive
.SUFFIXES:
am__CONFIG_DISTCLEAN_FILES = config.status config.cache config.log \
configure.lineno
$(srcdir)/Makefile.in:  Makefile.am  $(top_srcdir)/configure.in
$(ACLOCAL_M4)
	cd $(top_srcdir) && \
	  $(AUTOMAKE) --gnu  Makefile
Makefile:  $(srcdir)/Makefile.in  $(top_builddir)/config.status
	cd $(top_builddir) && $(SHELL) ./config.status $@
$(am__depfiles_maybe)
$(top_builddir)/config.status: $(srcdir)/configure
$(CONFIG_STATUS_DEPENDENCIES)
	$(SHELL) ./config.status --recheck
$(srcdir)/configure:  $(srcdir)/configure.in $(ACLOCAL_M4)
$(CONFIGURE_DEPENDENCIES)
	cd $(srcdir) && $(AUTOCONF)
$(ACLOCAL_M4):  configure.in
	cd $(srcdir) && $(ACLOCAL) $(ACLOCAL_AMFLAGS)
mostlyclean-libtool:
	-rm -f *.lo
clean-libtool:
	-rm -rf .libs _libs
distclean-libtool:
	-rm -f libtool
uninstall-info-am:
# This directory's subdirectories are mostly independent; you can cd #
into them and run `make' without going through this Makefile. # To
change the values of `make' variables: instead of editing Makefiles, #
(1) if the variable is set in `config.status', edit `config.status'
#     (which will cause the Makefiles to be regenerated when you run
`make');
# (2) otherwise, pass the desired values on the `make' command line.
$(RECURSIVE_TARGETS):
	@set fnord $$MAKEFLAGS; amf=$$2; \
	dot_seen=no; \
	target=`echo $@ | sed s/-recursive//`; \
	list='$(SUBDIRS)'; for subdir in $$list; do \
	  echo "Making $$target in $$subdir"; \
	  if test "$$subdir" = "."; then \
	    dot_seen=yes; \
	    local_target="$$target-am"; \
	  else \
	    local_target="$$target"; \
	  fi; \
	  (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS) $$local_target) \
	   || case "$$amf" in *=*) exit 1;; *k*) fail=yes;; *) exit 1;;
esac; \
	done; \
	if test "$$dot_seen" = "no"; then \
	  $(MAKE) $(AM_MAKEFLAGS) "$$target-am" || exit 1; \
	fi; test -z "$$fail"
mostlyclean-recursive clean-recursive distclean-recursive \
maintainer-clean-recursive:
	dot_seen=no; \
	case "$@" in \
	  distclean-* | maintainer-clean-*) list='$(DIST_SUBDIRS)' ;; \
	  *) list='$(SUBDIRS)' ;; \
	esac; \
	rev=''; for subdir in $$list; do \
	  if test "$$subdir" = "."; then :; else \
	    rev="$$subdir $$rev"; \
	  fi; \
	done; \
	rev="$$rev ."; \
	for subdir in $$rev; do \
	  else \
	  fi; \
esac; \
	done && test -z "$$fail"
tags-recursive:
	  test "$$subdir" = . || (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS)
tags); \
	done
ctags-recursive:
ctags); \
	done
ETAGS = etags
ETAGSFLAGS =
CTAGS = ctags
CTAGSFLAGS =
tags: TAGS
ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
	list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
	unique=`for i in $$list; do \
	    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i;
fi; \
	  done | \
	  $(AWK) '    { files[$$0] = 1; } \
	       END { for (i in files) print i; }'`; \
	mkid -fID $$unique
TAGS: tags-recursive $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
		$(TAGS_FILES) $(LISP)
	tags=; \
	here=`pwd`; \
	  if test "$$subdir" = .; then :; else \
	    test -f $$subdir/TAGS && tags="$$tags -i
$$here/$$subdir/TAGS"; \
	  fi; \
	done; \
fi; \
	  done | \
	test -z "$(ETAGS_ARGS)$$tags$$unique" \
	  || $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
	     $$tags $$unique
ctags: CTAGS
CTAGS: ctags-recursive $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
	tags=; \
	here=`pwd`; \
fi; \
	  done | \
	test -z "$(CTAGS_ARGS)$$tags$$unique" \
	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
	     $$tags $$unique
GTAGS:
	here=`$(am__cd) $(top_builddir) && pwd` \
	  && cd $(top_srcdir) \
	  && gtags -i $(GTAGS_ARGS) $$here
distclean-tags:
	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
top_distdir = .
distdir = $(PACKAGE)-$(VERSION)
am__remove_distdir = \
  { test ! -d $(distdir) \
    || { find $(distdir) -type d ! -perm -200 -exec chmod u+w {} ';' \
         && rm -fr $(distdir); }; }
GZIP_ENV = --best
distuninstallcheck_listfiles = find . -type f -print
distcleancheck_listfiles = find . -type f -print
distdir: $(DISTFILES)
	$(am__remove_distdir)
	mkdir $(distdir)
	@srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \
	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \
	list='$(DISTFILES)'; for file in $$list; do \
	  case $$file in \
	    $(srcdir)/*) file=`echo "$$file" | sed
"s|^$$srcdirstrip/||"`;; \
	    $(top_srcdir)/*) file=`echo "$$file" | sed
"s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \
	  esac; \
	  if test -f $$file || test -d $$file; then d=.; else
d=$(srcdir); fi; \
	  dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \
	  if test "$$dir" != "$$file" && test "$$dir" != "."; then \
	    dir="/$$dir"; \
	    $(mkinstalldirs) "$(distdir)$$dir"; \
	  else \
	    dir=''; \
	  fi; \
	  if test -d $$d/$$file; then \
	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
	      cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
	    fi; \
	    cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
	  else \
	    test -f $(distdir)/$$file \
	    || cp -p $$d/$$file $(distdir)/$$file \
	    || exit 1; \
	  fi; \
	done
	    test -d $(distdir)/$$subdir \
	    || mkdir $(distdir)/$$subdir \
	    || exit 1; \
	    (cd $$subdir && \
	      $(MAKE) $(AM_MAKEFLAGS) \
	        top_distdir="$(top_distdir)" \
	        distdir=../$(distdir)/$$subdir \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
	-find $(distdir) -type d ! -perm -777 -exec chmod a+rwx {} \; -o
	  ! -type d ! -perm -444 -links 1 -exec chmod a+r {} \; -o \
	  ! -type d ! -perm -400 -exec chmod a+r {} \; -o \
	  ! -type d ! -perm -444 -exec $(SHELL) $(install_sh) -c -m a+r
	|| chmod -R a+r $(distdir)
dist-gzip: distdir
	$(AMTAR) chof - $(distdir) | GZIP=$(GZIP_ENV) gzip -c
>$(distdir).tar.gz
dist-zip: distdir
	-rm -f $(distdir).zip
	zip -rq $(distdir).zip $(distdir)
dist dist-all: distdir
>$(distdir).tar.gz
# This target untars the dist file and tries a VPATH configuration.
Then # it guarantees that the distribution is self-contained by making
another # tarfile.
distcheck: dist
	GZIP=$(GZIP_ENV) gunzip -c $(distdir).tar.gz | $(AMTAR) xf -
	chmod -R a-w $(distdir); chmod a+w $(distdir)
	mkdir $(distdir)/=build
	mkdir $(distdir)/=inst
	chmod a-w $(distdir)
	dc_install_base=`$(am__cd) $(distdir)/=inst && pwd` \
	  && dc_destdir="$${TMPDIR-/tmp}/am-dc-$$$$/" \
	  && cd $(distdir)/=build \
	  && ../configure --srcdir=.. --prefix="$$dc_install_base" \
	    $(DISTCHECK_CONFIGURE_FLAGS) \
	  && $(MAKE) $(AM_MAKEFLAGS) \
	  && $(MAKE) $(AM_MAKEFLAGS) dvi \
	  && $(MAKE) $(AM_MAKEFLAGS) check \
	  && $(MAKE) $(AM_MAKEFLAGS) install \
	  && $(MAKE) $(AM_MAKEFLAGS) installcheck \
	  && $(MAKE) $(AM_MAKEFLAGS) uninstall \
distuninstallcheck_dir="$$dc_install_base" \
	        distuninstallcheck \
	  && chmod -R a-w "$$dc_install_base" \
	       (cd ../.. && $(mkinstalldirs) "$$dc_destdir") \
	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" install
uninstall \
	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" \
	            distuninstallcheck_dir="$$dc_destdir"
distuninstallcheck; \
	      } || { rm -rf "$$dc_destdir"; exit 1; }) \
	  && rm -rf "$$dc_destdir" \
	  && $(MAKE) $(AM_MAKEFLAGS) dist-gzip \
	  && rm -f $(distdir).tar.gz \
	  && $(MAKE) $(AM_MAKEFLAGS) distcleancheck
	@echo "$(distdir).tar.gz is ready for distribution" | \
	  sed 'h;s/./=/g;p;x;p;x'
distuninstallcheck:
	cd $(distuninstallcheck_dir) \
	&& test `$(distuninstallcheck_listfiles) | wc -l` -le 1 \
	   || { echo "ERROR: files left after uninstall:" ; \
	        if test -n "$(DESTDIR)"; then \
	          echo "  (check DESTDIR support)"; \
	        fi ; \
	        $(distuninstallcheck_listfiles) ; \
	        exit 1; } >&2
distcleancheck: distclean
	if test '$(srcdir)' = . ; then \
	  echo "ERROR: distcleancheck can only run from a VPATH build" ;
	  exit 1 ; \
	fi
	test `$(distcleancheck_listfiles) | wc -l` -eq 0 \
	  || { echo "ERROR: files left in build directory after
distclean:" ; \
	       $(distcleancheck_listfiles) ; \
	       exit 1; } >&2
check-am: all-am
check: check-recursive
all-am: Makefile
installdirs: installdirs-recursive
installdirs-am:
install: install-recursive
install-exec: install-exec-recursive
install-data: install-data-recursive
uninstall: uninstall-recursive
install-am: all-am
	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
installcheck: installcheck-recursive
install-strip:
INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
	  INSTALL_STRIP_FLAG=-s \
	  `test -z '$(STRIP)' || \
	    echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
mostlyclean-generic:
clean-generic:
distclean-generic:
	-rm -f Makefile $(CONFIG_CLEAN_FILES)
maintainer-clean-generic:
	@echo "This command is intended for maintainers to use"
	@echo "it deletes files that may require special tools to
rebuild."
clean: clean-recursive
clean-am: clean-generic clean-libtool mostlyclean-am
distclean: distclean-recursive
	-rm -f $(am__CONFIG_DISTCLEAN_FILES)
distclean-am: clean-am distclean-generic distclean-libtool \
	distclean-tags
dvi: dvi-recursive
dvi-am:
info: info-recursive
info-am:
install-data-am:
install-exec-am:
install-info: install-info-recursive
install-man:
installcheck-am:
maintainer-clean: maintainer-clean-recursive
	-rm -rf autom4te.cache
maintainer-clean-am: distclean-am maintainer-clean-generic
mostlyclean: mostlyclean-recursive
mostlyclean-am: mostlyclean-generic mostlyclean-libtool
pdf: pdf-recursive
pdf-am:
ps: ps-recursive
ps-am:
uninstall-am: uninstall-info-am
uninstall-info: uninstall-info-recursive
.PHONY: $(RECURSIVE_TARGETS) CTAGS GTAGS all all-am check check-am clean
	clean-generic clean-libtool clean-recursive ctags \
	ctags-recursive dist dist-all dist-gzip dist-zip distcheck \
	distclean distclean-generic distclean-libtool \
	distclean-recursive distclean-tags distcleancheck distdir \
	distuninstallcheck dvi dvi-am dvi-recursive info info-am \
	info-recursive install install-am install-data install-data-am \
	install-data-recursive install-exec install-exec-am \
	install-exec-recursive install-info install-info-am \
	install-info-recursive install-man install-recursive \
	install-strip installcheck installcheck-am installdirs \
	installdirs-am installdirs-recursive maintainer-clean \
	maintainer-clean-generic maintainer-clean-recursive mostlyclean
	mostlyclean-generic mostlyclean-libtool mostlyclean-recursive \
	pdf pdf-am pdf-recursive ps ps-am ps-recursive tags \
	tags-recursive uninstall uninstall-am uninstall-info-am \
	uninstall-info-recursive uninstall-recursive
# Tell versions [3.59,3.63) of GNU make to not export all variables. #
Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
