[OSRS-PROJ] Oblique Mercator, and Swiss Oblique Cylindrical
Wed Dec 11 12:49:51 PST 2002
Folks,
I am working on getting Swiss Oblique Cylindrical working properly in a
higher level tool build on PROJ.4, and am running into a number of problems.
1) The omerc projection in PROJ.4 does not let me select an azimuth of 90
    degrees.  My understanding is that Swiss Oblique Cylindrical is essentially
    Oblique Mercator with an azimuth of 90 but that is clearly considered a
    degenerate case in the PJ_omerc code (and it reports an error).  Is this
    just due to the mathematical formulation of the omerc code?
2) I have tried setting the azimuth quite close to 90 (ie. 89.99) and
    PROJ.4 seems to work but the results do not match what I am expecting.
    Off by a few thousand meters in my test case.  My test point was derived
    by using FME to reproject some swiss data into lat/long on the same datum.
    Does anyone have a sample point I could use in swiss oblique cylindrical?
    That is, the location in lat/long and soc?
3) Just to ensure I had a known starting point, I tried reprojecting the
    example point from the EPSG note on oblique mercator.  This is described
    in section 1.4.7 of their "Guidance Note # 7".  The section is available at:
     http://www.remotesensing.org/geotiff/proj_list/epsg_om.html
    However, I could get my results to agree.  Basically I tried:
      proj +proj=omerc +lat_0=4 +lonc=115 +alpha=53.31582047222222 +k=0.99984
         +x_0=590476.87 +y_0=442857.65 +ellps=evrstSS +units=m < rso_eg.dat
    where rso_eg.dat contains:
      115d48'19.8196"E 5d23'14.1129"N
      # 679245.73 596562.78 expected
    But instead of getting the expected results I get:
      679743.48       596274.24
    It is in the right ballpark, but still on the order of 600 meters off.
    Can anyone suggest where things are going wrong?
    Actually, looking over things, there doesn't seem to be a
    "rectified to skewed grid" argument in my proj.4 formulation.  Is that
    an issue?  I don't really follow the purpose of this parameter as opposed
    to the azimuth.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
