[OSRS-PROJ] Instalation problem: libtool versions
Norman Vine nhv at cape.com
Sun Dec 15 10:57:45 PST 2002
Luís Mota
> I'm having an installation problem similar to the one reported in
> http://www.remotesensing.org/lists/proj_archive/msg00429.html . This problem
> had a suggested solution in
> http://www.remotesensing.org/lists/proj_archive/msg00430.html, which I
> unfortunately could not understand...
> There is some kind of libtool version problem. The libtool which is in my
> system has version ltmain.sh (GNU libtool) 1.4 (1.920 2001/04/24 23:26:18)
> but, as I run 'make' I get the following error:
> /bin/sh ../libtool --mode=compile
> gcc -DHAVE_CONFIG_H -I. -I. -I. -DPROJ_LIB=\"/usr/local/share/proj\"    -g -
> O2 -c PJ_aeqd.c
> libtool: ltconfig version `' does not match ltmain.sh version `1.3.4'
> Fatal configuration error.  See the libtool docs for more information.
I think you just need to run libtoolize  % info libtoolize
or  just
% cd $PROJ_SRC
% libtoolize --force
HTH
Norman
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
