[OSRS-PROJ] PROJ and ellipsoid shifts
Tue Jan 8 07:12:17 PST 2002
Jean-Paul Berroir wrote:
> The command
> cs2cs  +ellps=WGS84 +proj=latlong +to +ellps=krass +proj=tmerc +lon_0=15
> +x_0=3500000
> gives me approximately the same figures, yet slighty different:
> y=3406478.97   x=5810764.06 (difference is 40m in x and 126m in y)
Jean-Paul,
I forgot a few items.  You should use +datum=WGS84 instead of +ellps=WGS84
in your definition.
eg.
./cs2cs -v +proj=latlong +ellps=WGS84 +to +proj=tmerc +ellps=krass
                       +lon_0=15 +x_0=3500000 +towgs84=28,-130,-95
> -last but not least, wanting to check my command before bothering you,
> I've asked for more info with option -v, and look at what is said about
> ellipsoid:
> (with above cs2cs command, option -v added)
> # ---- From Coordinate System ----
> #Lat/long (Geodetic)
> # +ellps=WGS84 +proj=latlong
> # ---- To Coordinate System ----
> #Transverse Mercator
> #       Cyl, Sph&Ell
> # +ellps=krass +proj=tmerc +lon_0=15 +x_0=3500000
> #--- following specified but NOT used
> # +ellps=WGS84
> how do I have to understand the last comment?
PROJ.4 defaults to appending +ellps=WGS84 in some cases.  This comment is
essentially telling you that this defaulted ellipsoid was ignored.  It isn't
a problem.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
