[OSRS-PROJ] Gradian Definitions
Mon Jul 29 05:37:38 PDT 2002
Paul Ramsey wrote:
> Attached find a patch against the 'nad/esri' file which converts the
> gradians to degrees in the definitions and alters the longitude to be
> relative to greenwich in the paris-origin cases. The affected
> projections are
> Those projections which are also in the 'nad/epsg' file should probably
> also be modified.
Paul,
I have applied the patch directly to the nad/esri file, and created Bug 184
to track fixing the OGR code used to generate the nad/epsg file.
   http://bugzilla.remotesensing.org/show_bug.cgi?id=184
Thanks,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
