[OSRS-PROJ] Units used in Expressing Projections
Gerald Evenden gerald.evenden at verizon.net
Mon Jul 29 18:37:39 PDT 2002
Yes, yes.  I complaining to myself about the several problems with conversion
to the proj script I elided over the tan/sec definition.  Indeed, lat_1=  k_0!=1.
is
secant form.
Somewhere I believe there is a formulae to convert lat_1 k_0 to double
parallel form and converse.
Clifford J Mugnier wrote:
> Gentlemen,
> The French use the secant case for Lambert Conformal Conics in France and
> Corsica.  The use of a Latitude of Origin and a Scale Factor at Origin is
> not a "Tangent case" unless the scale factor at origin is 1.0.  The one
> latitude they quote is NOT a standard parallel.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
