[OSRS-PROJ] Prime Meridian Support in PROJ.4
Gerald Evenden gerald.evenden at verizon.net
Thu Oct 3 12:38:43 PDT 2002
Just as an aside from the original author of proj.4:  prime meridian has no place
in
proj.4.  Any offsets in longitude due to variations in coordinate system "prime
meridian" should be taken care of externally with adjustments to "lon_0"
parameter.
My probem is that I view the projections and their math as pristene entities  and
not disturbed with regtional egos and their arbitrary orientations of coordinate
systems.
I know my advice will be ignored but I could not resist expressing my displeasure
with the inclusion of PM code within the proj.4 library.  PMS, if you will.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
