[OSRS-PROJ] Prime Meridian Support in PROJ.4
Luis Mota luis.mota at iscte.pt
Thu Oct 3 12:52:30 PDT 2002
Just sth I noticed:
You cite the srtext definition in the spatial_ref_sys table:
> PROJCS["Portuguese_National_Grid",GEOGCS["GCS_Lisbon_Lisbon",DATUM["D_Lisbon",SPHEROID["International_1924",6378388,297]],PRIMEM["Lisbon",-9.131906111111112],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",200000],PARAMETER["False_Northing",300000],PARAMETER["Central_Meridian",1],PARAMETER["Scale_Factor",1],PARAMETER["Latitude_Of_Origin",39.66666666666666],UNIT["Meter",1]]
However, when I looked at the definition found in
http://gdal.velocet.ca/cgi-bin/csv2html/TABLE=p_meridian/CODE=8902/, the
value for the prime meridian is -9.0754862. Which one is right? I don't
have the EPSG data here to check it out (I have no application to read
an Access DB... What idea is this to publish EPSG data in Access format?)
Bye, Luís
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
