[OSRS-PROJ] Winkel Tripel or Winkel 3 Projection
Paul Selormey paul at toolscenter.org
Sat Aug 23 17:06:29 PDT 2003
Thanks for the reply.
> I think the term "composite" needs some defining.  At first
> I thought you meant something like Goode's projection where
> two different projections are used in two different regions.
> In Winkel-Tripel, the Aitoff projection and the equirectangular
> are averaged.
The OpenGIS and EPSG used the term "Compound" and the meaning
could be taken from this extract from the OpenGIS specifications
"This indicates a compound coordinate system, which combines the coordinate
of two other
coordinate systems. For example, a compound 3D coordinate system could be
made up of a
horizontal coordinate system and a vertical coordinate system."
> The time-line for W1, W2 and WT is 1914, 1915 and 1921 so
> WT might be Winkel's third projection. (?)
We were probably misled by the Japanese document to think there was a "W3".
Could be a language/translation problem - or yet another Japanese simplified
term :-)
Best regards,
Paul.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
