[OSRS-PROJ] lib call results differ from exec results
Gerald I. Evenden gerald.evenden at verizon.net
Mon Jul 14 17:10:42 PDT 2003
For local execution of the runline:
echo "-110.969 39.7621"|./lproj +proj=aea +ellps=clrk66 +lat_1=20
+lat_2=60 +lon_0=110w +lat_0=40
-78175.38       -27659.27
which is a much more reasonable value for a point fairly close
to the projection origin of -110,40.
One problem is there is a "," (comma) in the input stream.
'lproj' or 'proj' only understand white-space delimiting.
As for the scanning of "default" file I must admit it was there
earlier and was always a curse.  Number one question after someone
installed the system was why it failed---most of the time the
default file could not be found.  Some setup failure.
I got rid of it but it still haunts me.
Gerald I. Evenden <gerald.evenden at verizon.net>
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
