[OSRS-PROJ] Re: Weirdnesses in the source code
Ton Hospel proj at ton.iguana.be
Sat Jul 19 09:29:05 PDT 2003
In article <1058203816.2418.11.camel at localhost>,
	"Gerald I. Evenden" <gerald.evenden at verizon.net> writes:
> The items of this previous bug list have been corrected in release
> 030714 at site:
> http://members.bellatlantic.net/~vze2hc4d/proj4/
> Again, thanks for the reports.  Keep the cards and letters coming.
Great. So let's note some more small details :-)
- Normally an azimuthal projection is declared as "Azi" in the PROJ_HEAD
  azimuthal/PJ_sterea.c uses "Azimuthal"
- a number of projections (cylinder/PJ_ardn_cls.c, cylinder/PJ_braun2.c,
        cylinder/PJ_cubic.c, cylinder/PJ_mill_2.c, cylinder/PJ_mill_per.c)
  use property "NI". I asume this means "no inverse". But all other places
  use "no inv" for that (for automatic parsing NI is nicer, for humans
  "no inv" is nicer)
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
