[OSRS-PROJ] Re: Weirdnesses in the source code
Gerald I. Evenden gerald.evenden at verizon.net
Sun Jul 20 08:35:14 PDT 2003
Corrections will be in the next release.
The eqdc error was more severe in that allocated memory was lost
but in both cases the chance of erroneous numbers was infinitesimal.
Nothing to be concerned about for current release and earlier.
On Sat, 2003-07-19 at 18:59, Ton Hospel wrote:
> In article <1058203816.2418.11.camel at localhost>,
> 	"Gerald I. Evenden" <gerald.evenden at verizon.net> writes:
> > The items of this previous bug list have been corrected in release
> > 030714 at site:
> Here two other minor ones:
> conic/PJ_bonne.c calculates P->en without checking the result for NULL
> conic/PJ_eqdc.c calculates P->en WITH checking, then in the eliptical
> case calculates it AGAIN (but now without checking).
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
Gerald I. Evenden <gerald.evenden at verizon.net>
