[OSRS-PROJ] PROJ 4.4.6 Release
Paul Ramsey pramsey at refractions.net
Tue Mar 4 11:35:50 PST 2003
I'd like to give you an improved ESRI file, Frank which *only* includes
codes used by ESRI. Note that ESRI included most (but not all) of the
EPSG codes in their coding scheme. They also seem to have tried to avoid
collisions. There were somem problems in the last file I gave you with
Stateplane projections in feet.
Paul
Daniel Morissette wrote:
> Frank Warmerdam wrote:
>>  o Updated 'espg' translation file for EPSG 6.2.2 with better support for
>>    prime meridians.
>>  o Added 'esri' pseudo-epsg coordinate system file.
> Frank,
> Do you know the difference between the contents of the epsg file and the
> esri file?  It seems to me that the esri file contains most if not all
> of the epsg codes, plus about a dozen ESRI-specific codes.
> Can you, or someone else confirm that the esri file is just an older
> version of the epsg file to which these 12 ESRI-specific codes have been
> added at the end?  If that's the case then should we update the esri
> file in the distribution to be based on the latest epsg file?
> Thanks
> Daniel
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
