[OSRS-PROJ] New projection routines??
Paul Selormey paul at toolscenter.org
Fri Mar 7 20:06:23 PST 2003
Hello Gerald,
Thanks for the response and the information.
> The original figures in the pdf distributions came from two
> sources: MAPGEN and PLOTGEN and my device independent plotting
> routine.  I have dropped doing anything with both projects as
> they are pretty much out of date and I don't know anyone using
> them.  Since gnuplot has been around a while and I figure I might
> as well use it in any new effort.
Hmmm...never heard of MAPGEN and PLOTGEN, have used GNUPlot a
lot in the past.
I hope you will do the plotting routine in C to make it portable to other
platforms too :-)
> Mike Schmidt has started on redoing the documentation but
> the last I checked he had been stalled with other duties.
> At the moment, my concerns are documenting new material
> and not duplicating anything he does although I am interested
> in getting the illustrations up to date.
Yes, he is the one I was refering to. He had some initial problems with
the format, do not know if he is able to resolve it.
I was suggesting LaTeX, since it can be compiled to DVI, PDF, PS etc.
What is the format of the original documentations (before converted to
the pdf)? Can this be released to the public?
Best regards,
Paul.
> On Fri, 2003-03-07 at 21:21, Paul Selormey wrote:
> > Hello Gerald,
> > Thanks for the commitment to the development of the Proj4.
> > Were the original figures generated with GNUPlot?
> > On the documentation, someone here started a similar effort,
> > do not know the state though. You might wish to contact him
> > for a discussion.
> > Best regards,
> > Paul.
> > ----- Original Message -----
> > From: "Gerald I. Evenden" <gerald.evenden at verizon.net>
> > To: <osrs-proj at remotesensing.org>
> > Sent: Saturday, March 08, 2003 4:30 AM
> > Subject: [OSRS-PROJ] New projection routines??
> > > To the best of my knowledge, I am caught up on OSRS's *projection*
> > > needs.  If not, please queue up your requests.
> > > In the mean time, I am working on few problems here: 1) review figure
> > > generation using GNUplot, 2) finishing documentation on a couple of
> > > minor projections and 3) considerations on general documentation.
> > > PROJ.4 Discussion List
> > > See http://www.remotesensing.org/proj for subscription, unsubscription
> > > and other information.
