[OSRS-PROJ] Pb with conversion betwenn WGS84 and Lambert
Aurélie Lebreton aurelie.lebreton at dryade.net
Fri Nov 21 00:35:09 PST 2003
Thank you, it's the good value.
In the 2400000, the 2 correspond to the 2 of the lambert 2 in France but
it's normal that it doesn't appear in the value.
-----Message d'origine-----
De : owner-osrs-proj at remotesensing.org
[mailto:owner-osrs-proj at remotesensing.org]De la part de Frank Warmerdam
Envoyé : jeudi 20 novembre 2003 20:09
À : osrs-proj at remotesensing.org
Objet : Re: [OSRS-PROJ] Pb with conversion betwenn WGS84 and Lambert
Aurélie Lebreton wrote:
> Hello
> I want to transform a pair of angular coordinates in datum WGS84 to NTF
> Lambert 2. I have written this line :
> ./cs2cs +proj=latlong +datum=WGS84 +ellps=GRS80 +to +proj=lcc
+lat_0=46.8000
> +lat_1=46.8000 +lon_0=2.3372291 +k_0=0.99987742 +x_0=600000 +y_0=200000
> +a=6378249.2 +b=6356515 +ellps=clrk80
> The input coordinates are :
> 2d39'48882"E 48d32'8575"N
> But the coordinates transformed come out wrong and i don't understand why
> 1575621.19      743408.43 0.00
> (the coordinates should turn around these values :
>  600000 2400000
> Does any one have the solution to this, or at least some in depth
> documentation on how to use proj ?
> Aurelie
Aurelie,
The main problem is your DMS specification: 2d39'48882"E.  I imagine
you mean 2d39'48.882"E (that is 48.882 seconds, not 48882 seconds).
You may also find you need to include +towgs84=0,0,0 in the NTF coordinate
system to ensure that the ellipsoid conversion is done, even though no datum
shift info is available.
With the DMS specs fixed I get:
warmerda at gdal2200[265]% cs2cs +proj=latlong +datum=WGS84 +ellps=GRS80 +to
+proj=lcc +lat_0=46.8000 +lat_1=46.8000
+lon_0=2.3372291 +k_0=0.99987742 +x_0=600000 +y_0=200000 +a=6378249.2
+b=6356515 +ellps=clrk80 +towgs84=0,0,0
2d39'48.882"E 48d32'85.72"N
624110.53       395817.08 83.91
This value looks reasonable.  I am not sure why you were thinking the
northing should be in the range of 2400000m.  48d32' is less than 2 degrees
north of the reference point (46.8) and a degree is roughly 100000m.  So
the value I got (395817m N) is roughly 2 degrees north of the reference
point
which makes sense.
Note that without good datum shift information the precision of the
conversion will not be great.
Good luck,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
