[OSRS-PROJ] Re: On the Ellipsoidal Transverse Mercator
Strebe at aol.com Strebe at aol.com
Wed Oct 15 12:00:18 PDT 2003
Gerald Evenden <gerald.evenden at verizon.net> writes:
> A question here, are we talking about the Gauss-Kruger model or some
> other construct?  Dozier, Lee are dealing with the Gauss-Kruger model.
There is no other construct. If the projection maps the ellipsoid conformally
such that the central meridian everywhere is unity, and the map is not
interrupted along the central meridian, then the map is the ellipsoidal transverse
Mercator = Gauss Kruger. All methods yield the same results if they are pursued
with unbounded accuracy. That is true of any conformal projection: if you
supply a boundary condition, then you have specified the entire conformal map.
> The description below contains exotic concepts and lacks sufficent
> detail for review.  Without detailed, published description it remains
> an unfounded claim.
No, Mr. Evenden, the description is complete and mundane. Anyone who
understands both the transverse Mercator and complex analysis would recognize it as a
legitimate path to the ellipsoidal transverse Mercator. Your insecure
insistence upon a published description is your loss, not mine; I and probably many
other people reading this list are perfectly capable of generating correct maps
with it. I have wheedled Wallis to publish. It's none of my concern if he does
not and it is not my place to publish his method. I'm afraid you'll have to
waffle through Dozier's account, since the best I can supply is references to
Snyder, Dozier, and Lee, Dr. Wallis's name and location, source code,
distortion analyses, comparisons with UTM coordinates, and images.
> Dr. Wallis claims that the publication of his transverse mercator
> is pending.
It will be awhile, he has told me, since it seems what he is writing is a
book that goes far beyond just a method for generating the ellipsoidal transverse
Mercator. It would not satisfy you anyway, since I do not expect it will be
peer-reviewed.
> Apparently the map is segmented.
It is not segmented. Two tombstones meet foot-to-foot, and two sets of such
conjoined tombstones meet side-by-side. The tombstone shape is the classical
simple rectangle with one end rounded as a semicircle.
> Note: Wallis only refers to mapping the N -or- S hemispheres
> whereas general concept of TM has no difficulty in the N-S
> direction but rather in the E-W direction.
Bizarre interpretation. Wallis clearly states that the entire north or south
hemisphere is mapped. He's not talking about "direction"; he's talking about
the extent of the map. The spherical transverse Mercator cannot map the entire
north or south hemisphere.
> BTW: is there a plotted example of this version of the transverse
> mercator available on the web somewhere?
No, but if someone were to supply a place to deposit it, I would be happy to
supply some. I can't imagine why you would be interested in pictures of
unfounded claims, though. And there is no such thing as "this version"; all
transverse Mercators are the same.
All who might be interested and don't find themselves consumed by
pathological skepticism, or who understand the method and therefore have no need for
skepticism, feel free to contact me with questions.
Regards,
daan Strebe
Geocart author
<A HREF="http://www.mapthematics.com">http://www.mapthematics.com</A>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20031015/4bc5def2/attachment.html>
