[OSRS-PROJ] Changes in EPSG codes?
Fri Oct 24 07:53:25 PDT 2003
Jan-Oliver Wagner wrote:
> On Fri, Oct 24, 2003 at 09:26:39AM -0400, Frank Warmerdam wrote:
>>What I would kind of like to have is a n "epsg_plus" table with all current
>>EPSG definitions, plus ones deleted from older versions, plus ESRI custom
>>codes.  This could then be used by folks wanting to maintain a maximimally
>>fleshed out set of definitions for MapServer and similar applications.
>>However, building such a thing is not a trivial effort.
> I propose to keep the deprecated ones in a separate file. It is easy
> to merge if wished.
> Attached is a startfile "nad/epsg-deprecated" together with a
> corresponding patch for README. This would at least
> explain the situation for others. Maybe eventually someone finds
> the time to complete the file systematically.
Jan-Oliver,
Change applied.
It would be nice to auto-generate the deprecated file, but that is pretty
hard to do because of the varying structure of the database over the years.
But I will add any requested submissions to the file in question.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
