[Proj] Snyder ISEA
Strebe at aol.com Strebe at aol.com
Tue Oct 18 20:46:25 PDT 2005
Snyder described at least three methods for creating customizable equal-area
projections, as well as an equal-area projection for arbitrary polyhedral
faces. I'm not aware of any of them called "ISEA".
See:
"Optimizing equal-area map projections using least squares", American
Congress on Surveying and Mapping, Reno, ASPRS-ACSM 1987 Fall Convention, ACSM
Technical Papers, p. 5-13.
"An equal-area map projection for polyhedral globes," Cartographica, Vol. 29,
No. 1, Spring 1992, pp. 10-21.
"New equal-area map projections for noncircular regions," The American
Cartographer, Vol. 15, No. 4, October 1988, pp. 341-355.
"Minimum-error equal-area map projections," (with John A. Dyer), The American
Cartographer, Vol. 16, No. 1, 1989, pp. 39-43.
Regards,
daan Strebe
In a message dated 10/18/05 09:53:13, zhangli at supermap.com writes:
> Hi,
>    Does someone know  Snyder Equal Area (ISEA) projection?   Or where can I
> find some information about this projection ?
>    Any suggestions is appreciated.
>    Thanks.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20051018/6739a00a/attachment.html>
