[Proj] Roussilhe Projection
Wed Oct 19 13:57:39 PDT 2005
On 10/19/05, Steffen Macke <sdteffen at gmail.com> wrote:
> Dear Developers,
> is there a chance that the rouss projection from Gerald Evenden's libproj
> version will be included in proj.4?
Steffen,
I am not opposed to incorporating this.  Submit an enhancement
request via bugzilla if you wish.  It should also be pretty easy to
merge the code in manually at your end if you have a pressing
need.
Best regards,
